First time poster but long-time reader. Great forum!
I got my MK7 Golf TDI (auto DSG) into the settlement fix about two months ago in Toronto. At the time, I hadn't even done the Phase 1 fix yet, so they did the entire fix (phase 1 and 2) simultaneously. Ever since then, I've noticed a very discernible rumble at low RPM in pretty much every gear, but most noticeably from 1 thru 4. If I'm coasting with foot off the pedal it won't happen, and will only trigger when I'm accelerating through that RPM range. Also, I'll only be down in that RPM range if driving very light. If driving more spirited, then it will usually up shift above that RPM range or at least accelerate through it quickly where it is not as noticeable.
It feels like it's coming from the engine bay, but that could just be vibration transmission. It can be felt most through the steering wheel and the seat (which is kind of obvious because those are the points of contact with the car interior). I've searched online and this seems to be a common behavior for TDIs, but I never experienced it to this degree until after the TDI fix. Perhaps the reprogramming changed the shift points to up shift faster and thus stay in a lower RPM?
I brought it back to the dealer that did the fix, and they told me it was 'normal', although in all honesty they never spent long enough with the car to really diagnose the issue (they spent longer on an alignment issue that also popped up after the fix).
Just curious if others have experienced this as well post fix? I can live with some rumble, but this is to the point where it is unpleasant to drive. And it definitely was not like this before the fix.
Thanks in advance for any inpput/advice!
