TractionAction
I have a 2003 Jetta TDI that does not have the fog light option. The prior owner installed HID lights with fog lights.
So I bought the light switch with the fog light option (pull to turn on). Still won't work.
After some checking the "NL" socket is missing the wire from the factory. How hard would it be to get a mini connector and run the wire myself? Looks like the fuse etc is connected.
Has anyone done this? If so, please share what you did to get the fog lights to function.
