dmodderman
Hello,
I am researching options for code scanners for my recent TDI purchase (2006 Jetta Wagon, A4). So far I have come across a few options but have not found a good side-by-side comparison on these forums. Please correct me if I'm wrong or if there are other options available, but here is my list so far:
1. VAG-COM at Ross-Tech - includes software and adaptor to use my existing computer to interact with the car (seems to be considered the best option). Requires a Bentley Repair Manual to interpret codes.
2. OBD-II scanner - may not be that useful as may only interpret certain codes primarily related to emissions controls. I assume the Bentley Repair manual would cover codes for this (?)
3. VAG 305 scanner I came across on ebay. My primary question is how this option compares with the two above options. I assume the Bentley Repair manual would cover codes for this (?)
I'm not sure that I would really utilize the capabilities of the VAG-COM and therefore it may not be worth spending that much for me. What is the second best option to VAG-COM that I should be considering? VAG 305? OBD-II? Other?
