JBizz
So i got my car back last week and notice a little wobble at 35-40 mph at 1200rpms did they miss install something? I can always get it to happen at 35 but not at lower gears (dsg) anyone else get a wobble after phase2?
wobble? in steering wheel? whole car?
I'd first check you lug bolts to cover your but.
Depending if you got both kits or not, they do have to remove the front subframe. My work order showed they aligned it. I have no proof (No spec sheet), but it is driving correctly and was told it was checked. I'm due for an alignment anyway, so personally I will trust who I use for alignments and take it there in the next few weeks. But for you, I'd take it back to VW and ask to have them check the car as there wasn't an issue before.
My steering wheel and car wobble n shake. Ill look over my work order after work but they did say my rear did need adjustment. But it didn't look right on paper. Thr toe was perfect and each rear wheel needed like 1.02 adjusting.. I drove it 800 miles right after the shop.noticed it around 240 miles into the trip but keep at it. Tried to watch my wheels while driving didn't see much play. If i feel it in the steering wheel cam it be rear wheel problem? Ill post more after work.Did they forget to tighten the lug bolts properly?
And what do you mean by "wobble"?
