2TDIguy
- Joined
- Nov 23, 1999
- Location
- Lincoln, NE, USA
I looked at about 7 different threads about 96/ 97 glow plug relays. It appears the 96 models had the relay mounted in the relay panel and the 97's had it hanging in the wiring way up behind/ above the fuse/ relay box. I even released the fuse/ relay panel to drop it down and could not see it. Any hints? Also, I read there is a 50 or 80 amp fuse up there somewhere too? My symptom which just appeared Saturday is that no matter what temp the car is (even when sitting out at what has been around 10 degrees max the past 3 days here) the GP light only lights for 3 sec. If I unplug the coolant temp sensor they run for 20-30 secs. Not sure where to start but though I would check that 50/ 80 amp fuse. Does that cause a "quick" glow cycle when blown?
