Procedure for changing the fuel filter, no mention is made as to the priming procedure after the filter change........
Y because Bentley manuals are written by bunch of idiot Technical Writers. They aren't Designers/Engineers. They wouldn't know how to pre-fill fuel filter with Diesel fuel, and priming it to prevent dry start-up at the injectors. Injectors are lubricated by Diesel fuel not air.
fdizz said:
So I'd say this proves the whole "priming bs", as BS...
No, pre-fill fuel filter with Diesel fuel and priming it aren't BS.
Before the fuel filter or any part of the of fuel system i.e. hose is removed , the system is pressurized with Diesel fuel. Therefore, when you open the FFH, the fuel system is depressurized. So when the FF is replaced with a new one, the FFH has to be pre-filled with Diesel fuel - there was Diesel fuel in the FFH wasn't it? - and fuel system needs to be pressurized - it was pressurised wasn't it -. This will prevent dry start-up since injectors are lubricated with Diesel fuel not air.
Remember this rule of thumb:
- Always replace fluid that is removed before starting.
- Always pressurise system when it's depressurized before starting
Btw, have you ever done Brake, A/C system etc. flush? Same concept
DieselMann99 said:
What happens if you don't fully prime the fuel system or use the VCDS? Will it just take longer to start until it pumps all the way through? Or is there some damage that could occur?
No or half pressurized fuel system, dry start-up etc. are not a good thing
