MK5 Golf GT TDI Wheel Spacers caution when lowered
falk_ben
Stanley, Falkland Islands
2007 GT 170 (+/- 300 hp)
Just fitted Porsche 6-pots up front with 15mm spacers on my R32 18"s
(dropped 20mm) with no problems
I had rubbing issues on the outer wheel arch on cornering and when loaded up. My mistake was to match the fronts at 15mm:eek:
Now i have a nice set of Forge 11mm Spacers with no issues.
Min front is 11mm + to fit Porsche Brembos. 15mm gives plenty of clearance
Max Rear is 11mm
Hope this helps to avoid burning rubber smells when driving!:D
Ol'Rattler
PNA
2006 BRM Jetta
Lowering and wrong size tires and wheels. Some of the greatest handling downgrades you can do to your car. Lets see: "My car handles and drives perfectly as delivered from the factory. Seriously, I need to do me some downgrades that will make the car handle poorly and as a bonus make it unsafe to drive."
falk_ben
I agree but I had to have the brembo conversation. Just followed a You Tube video and they had 15mm upfront. When they were fitted I had 5 or so mm of gap between wheel and calliper.
Handling and cornering is miles better.
I could reduce fronts to 11 mm but no problems so far. In autumn I have plans to go with 35 profile tyres, with the sacrifice of harshness.
