perdurabo
I've got an 03 Golf TDI with 110k miles and an automatic transmission. For the past couple weeks I've been noticing that when I start the vehicle up in the morning I can put it into reverse just fine to back out of my driveway but the very first time I put it in drive, it seems the transmission "lurches", that is there a significant delay between hitting the accelerator and having resultant movement. If I happen to be heading up a hill/incline very soon after putting it in drive and moving from a dead stop, the lurch is relatively violent with a noticeable "vroom-CLUNK!" as it finally gets in gear.
This only happens when the engine has been cold and seems to go away once its heated up and it only happens when starting from a dead stop... subsequent gear changes feel normal. No check engine lights, etc. Despite what VW says about the auto transmission fluid being a "lifetime" fill, I was told by my VW specialist mechanic that its a really good idea to change the transmission fluid at around 100k miles when you also do the dreaded timing belt/water pump replacement job, so I did. Its been running fine for the last 10k miles or so up until recurrently when all this started.
Any ideas what might be causing this OTHER than a failing transmission? I trust my mechanic when it comes to everything else, but transmission issues are a completely different animal and I'd like the full set of options before a blow a huge chunk of money perhaps unnecessarily.
