patters1978
Hi everyone
Car - Passat 1.6tdi bluemotion 2012 start/stop engine code CAYC
Problem - car started having faults starting with coil light, engine light, error start/stop, diesel filter to the point original battery died. This was due to once the key is taken out of ignition the car doesn’t think it is and primed the car
Have replaced battery (not coded to car yet)
First start all errors apart from diesel filter disappear but once key is removed engine again primes? Only way to stop it is if the battery is removed or relay 100 is removed from the fuse box in engine bay (lucky guess just pulled it to see)
No fault codes as weekend no where open
See https://youtu.be/ves27j14Abo
Any help would be very appreciated
Located Tamworth uk
Cheers
Ps end of video is car trying to starting without clutch or 100 relay in
Located Tamworth uk
Cheers
