As its getting colder here is Michigan I have noticed a whine after cold starts. It happens very near 2k rpm, but only happens under load. Not speed related, just rpm. The more load the louder it is. The noise is lower pitch and sounds like if you were to a say "who" but hold the o "whooooooo..."
My questions:
1) I replaced my water pump this summer. Could it be a seal leak causing cavitation?
2) Any tips for how to diagnosis? I can't re-create unless it is under load and cold...
3) Would i be asking for trouble if I took a short drive (<1mile) without the power steering/water pump belt on. When it was cold?
4) Oil light blinks 1-2 times at engine start then goes away. It's not low on oil. related?
5) Any other thoughts?
1998 jetta mk3 tdi 310,000. I run walmart synthetic every ~5k.
Other notes:
Flushed the power steering. That didn't help.
I appreciate your time!
My questions:
Other notes:
