ssjimbo
I put in my new flywheel on Saturday and then realized that I forgot to put on the dust cover (or whatever you call it). I pulled the flywheel yesterday and know that I am supposed to replace the bolts. Just out of curiosity, I measured the bolts and they measured between 19.4 and 19.5 mm on a digital caliper. Spec on a new bolt is 19.5 mm, so if these stretched it was not very much at all.
So what happened here. Are the bolts toast? I know they designed to be single use. I know many people use them multiple times, but that's usually after many years/thousands of miles. Does it make sense that these bolts wouldn't lengthen permanently in 1 day? Thanks.
