My comments about the BEW may not have any application at all to the BHW, but based on my experience it may be worth a look around to see if there's a recommended installation procedure for the BHW. And frankly, again in my experience, the (my) dealer was not the answer in the case of the BEW installation procedure.
It just seems odd that your upper pipe would break again in such a short time -- it's not something we see posted here very much. While it bolted up just fine, it may possibly have bolted up in a position that put it under some stress -- or not. Just thought I'd throw it out there for consideration. Again, good luck.
Good call Tom_B...EGR cooler was loose. The engine is doing some serious vibrating and some of the bolts had been damaged from the vibration so they replaced the mid and the rear bolts. I hadn't opened the hood with the engine running in a while and I was surprised by how much vibration was going on in there. I guess I got accustomed to it.
I was told they couldn't do the front bolts without removing the turbo. So a new EGR cooler pipe is on order and I'll be replacing it myself (again) when it comes in. That will take care of the immediate problem.
Also found that the grinding noise that started this weekend was related to the AC not working and not the TC/tranny (thankfully). However, the AC compressor clutch has sheered off. So that means a new AC compressor is needed. Although I live in Maine, I do want working AC for defrost and the stop and go traffic I deal with to/from my job in Massachusetts. I can deal with it for the short term but long term it needs to be addressed. But with the clutch out of the system at least the noise is gone.
We're not sure what's causing the excessive engine vibration. They did mention that they had seen a similar vibration recently that, after much troubleshooting, was ultimately fixed by a transmission fluid and filter change. They couldn't say with certainty that it would fix my problem but threw it out there as an option. They did not think motor mounts would fully address the amount of vibration we were seeing.
I had a similar tranny service done @ 200K miles (same time as the balance shaft) but I'm not sure I'm willing to do it again @ 336K. I don't want to induce problems in the transmission that will set me back another $4K. The car still has a little resale value left but if the TC/tranny goes then so does any remaining value.
I also know from various postings here that an axle going bad might cause vibration. We didn't talk about that. Is there an inexpensive way to check the axles?
Would a compression test be useful in predicting remaining life expectancy on the block itself? Any other thoughts out there?
