cevans
TDIClub Enthusiast, TDI Parts Ninja Vendor , w/Bus
IDParts - Get Ready for Winter w/ Glow Plug & Harness Sales, Belly Pans, Frostheaters
So, just like last year, we've put glow plugs and harness sets on sale:
TDIClub Exclusive Preview of IDParts October Specials
Every winter TDI owners go through a certain routine. Perhaps an engine light comes back on or early morning starts get a bit smokey. Whatever the case, now is the time to consider replacing glow plugs and the glow plug harness/contact bridge.
- Glow Plug & Harness Kit (Late ALH 2002+)
- Glow Plug & Harness Kit (BEW)
- Glow Plug & Harness Kit (Early ALH / AHU / 1Z)
- Glow Plug & Harness Kit (BRM)
IDParts Aluminum Belly Pan & Sideskirt Set!
Last year we introduced the lowest-cost belly pan option available. Cut out of a single sheet of aluminum, this belly pan weighs less than 5 pounds and is nearly half the cost of a new OEM pan. We combine this pan with new, OEM sideskirts in our Belly Pan & Sideskirts Underbody Set for A4 chassis cars. We include a full set of hardware too with OEM torx screws too!Frostheaters
IDParts now stocks the FULL line of Frostheaters, the OE quality coolant heaters that are custom fit for VW TDIs. Even better, we created a combo special that takes $5 off a gallon of coolant when you get any Frostheater!
