LVPAJetta
Hello All - I could really use some help with getting my information in order before taking my car to the dealer. I'm going to first lay out the timeline of events, and then I'll post the logs. Not all facts may be relevant, but I'm putting down anything that may help. I guess a silver lining here is that this all pushed me to just go out and by my own Vag-Com.
Bought Car June 2017 - No real obvious/known issues until Nov. 2018. No Tune, No modifications other than aftermarket headlights. Only observation is that when the HVAC is set to window defrost, no air comes out of the driver side vent to blow on the side window. Also, when the defrost is selected the MGP really, really seems to take a hit from the compressor running.
One bit that is odd is the "heated seat" error code. I do not have heated seats.
Nov 15th - Snow in NJ/NYC, Complete chaos, and an 8hr drive home (50 mi)
Nov 19-23 - Sporadically Passenger airbag light on dash flashes and seat belt warning light comes on with nobody in the passenger seat.
Nov 23rd - 11F overnight temp. Flashing glow plug light, no CEL, Limp Mode until restart. OK afterwards.
Nov 26th - Mike at M&M pulled the codes and reset the log. There were "CAN Bus" reports and one code for "Turbo Actuator failed Response" (getting actual codes from Mike later today, will follow up later w/ log)
Nov 27th thru Dec 28th - No CEL, ECM, seatbelt, or other reported issues... however, the fuel economy as hand calculated fluctuated from 42.2 to 46.6 (historically had been 46-51 mpg)
Dec 30th - Overnight temps between 15F & 20F. Coming downhill Flashing glowplug light, slight stutter in engine, Brake pedal goes rigid after about 1/2"-1" of throw.
Dec 31 - CEL stayed on, but car did not go into limp, brakes worked.
Jan 1 - CEL goes out. Car averages about 40 mpg on drive home.
Jan 2 thru Jan 4 - Car is averaging about 47 mpg, but will need to confirm when I fill up.
I pulled the codes this morning after my drive to work, and below is what came up. Any help to know what this might be before I hand the car over to the dealer would be greatly appreciated.
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
75-Telematics -- Status: OK 0000
Address 01: Engine (J623-CRUA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 C HW: 04L 907 309
Component: R4 2.0l TDI H23 9282
Revision: 85H23---
Coding: 01190012032410081000
Shop #: WSC 00020 444 00000
ASAM Dataset: EV_ECM20TDI01104L906021C 004014
ROD: EV_ECM20TDI01104L906021C_004.rod
VCID: 2517F3F0656AE2EFCDD-8070
2 Faults Found:
7934 - Turbocharger Boost Control Position Sensor Circuit
P2563 00 [096] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 64213 km
Date: 2018.12.30
Time: 07:37:00
Engine speed: 1005.00 /min
Normed load value: 25.1 %
Vehicle speed: 22 km/h
Coolant temperature: 10 °C
Intake air temperature: -4 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.540 V
Unlearning counter according OBD: 27
Turbine actuator 1 bank 1: posit.feedback - Spec.value: 100.00 %
Turbine actuator 1 bank 1: posit.feedback - Act.value: 24.30 %
Turbine actuator 1 bank 1: posit.feedback - Offset closed: -1.45 %
Turbine actuator 1 bank 1: monitoring - status-Bits 0-7: 0
Turbine actuator 1 bank 1: monitoring - status-Bits 0-7: 55
Turbine actuator 1 bank 1: monitoring - status-Bits 0-7: 69
Turbine actuator 1 bank 1: monitoring - status-Bits 0-7: 14
Turbine actuator 1 bank 1: posit.feedback - Uncnd vlt: 3450.6 mV
Accelerator pedal travel: raw value: 0.00 %
9127 - Actuator Module for Turbocharger 1
P00AF 00 [104] - Stuck
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 64213 km
Date: 2018.12.30
Time: 07:37:01
Engine speed: 991.50 /min
Normed load value: 37.3 %
Vehicle speed: 17 km/h
Voltage terminal 30: 14.780 V
Unlearning counter according OBD: 29
Turbine actuator 1 bank 1: posit.feedback - Spec.value: 0.00 %
Readiness: 0 1 0 0 0
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 50975000000113
Coding: 04FA6AA1242109710078020181CA2520562490004081A4B200630050C002
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033
ROD: EV_Brake1UDSContiMK100ESP_034_VW37.rod
VCID: 47CB5978BF2610FF1F1-8012
1 Fault Found:
16401 - Tire Pressure Warning
C102D 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 215
Mileage: 21847 km
Date: 2017.11.20
Time: 07:05:52
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 5Q0 959 435 A HW: 5Q0 959 435
Component: VWKESSYMQB 021 0604
Revision: 00021000 Serial number: 0365032377
Coding: 030C0C
ASAM Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB_002.rod
VCID: 3A2D308CFCD47D1790F-806E
No fault code found.
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5GM 907 426 HW: 5GM 907 426
Component: AC Manuell H02 1001
Revision: 00001K01
Coding: 02020104202100000000000000000000
ASAM Dataset: EV_ACManueBHBVW37X 003019
ROD: EV_ACManueBHBVW37X_003_VW37.rod
VCID: 05579370C5AAC2EFADD-8050
Fresh Air Blower Front:
Refrigerant Pressure And Temperature Sender:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-BV1.clb
Part No SW: 5Q0 937 087 Q HW: 5Q0 937 087 Q
Component: BCM PQ37BOSCH 028 0145
Revision: -------- Serial number: 86582903150240
Coding: 000108424041804169E44000000403001800000000000000000000000000
Shop #: WSC 00066 790 00228
ASAM Dataset: EV_BodyContrModul1UDSBosc 014004
ROD: EV_BCMBOSCH_014.rod
VCID: 49CF5F40A932E68F095-801C
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150318 043 0581
Serial number: 150513222133
Coding: 0E4DDD
8 Faults Found:
131330 - Supply voltage
U1011 00 [008] - Voltage too Low
[VersorgungsspannungSpannung zu niedrig]
131586 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
5386 - Bulb for Front Right Turn Signal
B11EA 15 [008] - Open or Short to Plus
14602 - Bulb for Left Brake Lamp / Tail Lamp
B133A 15 [008] - Open or Short to Plus
17674 - Bulb for Front Left Side Marker Lamp
B12BA 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 228
Mileage: 15175 km
Date: 2017.09.17
Time: 13:51:58
17930 - Bulb for Front Right Side Marker Lamp
B12BB 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 228
Mileage: 15157 km
Date: 2017.09.17
Time: 12:39:23
204290 - Remote key 1
B1479 18 [008] - Current Too Low
329480 - Heated Passenger Seat
B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
Freeze Frame:
Fault Priority: 6
Fault Frequency: 24
Reset counter: 46
Mileage: 61996 km
Date: 2018.12.16
Time: 11:34:08
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 009 0825
Serial number: 003GCR01K070
Coding: 8CCCFC00000000005000001AC24800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002138
ROD: EV_AirbaVW20SMEVW37X.rod
Occupant Detection:
Subsystem 1 - Part No SW: 4M0 959 339 B HW: 4M0 959 339 B
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J150002OIYT06
Coding: 303138
Side Sensor Driver Front:
Subsystem 2 - Part No SW: ----------- HW: 480 003 003 15
Component: SideSensor_Df 001 0887
Serial number: 357000000009190DE31M
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 3 - Part No SW: ----------- HW: 480 002 603 15
Component: SideSensor_Pf 001 0887
Serial number: 35800000000CB1DCB31.
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 402 303 15
Component: SideSensor_Dr 001 6149
Serial number: 3510002C319DB89532CD
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 5 - Part No SW: ----------- HW: 480 403 103 15
Component: SideSensor_Pr 001 6149
Serial number: 3520002C71941311E17U
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 402 603 15
Component: FrontSensor_D 001 6149
Serial number: 35500029919EFF51035F
Coding: 2D2D2D
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 603 15
Component: FrontSensor_P 001 6149
Serial number: 35600029919EFF55B26V
Coding: 2D2D2D
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150331500208
Coding: 0400
Shop #: WSC 66564 385 16448
ASAM Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 04518E74CE90FBE7BA3-8050
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 841 HW: 5G1 920 841
Component: KOMBI 243 4270
Coding: 0BA412122180CF0502086A001000000000000000
Shop #: WSC 00066 790 00087
ASAM Dataset: EV_DashBoardVDDMQBAB 009037
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 6597B3F025EA22EF0DD-8030
1 Fault Found:
13635840 - Supply voltage
[Versorgungsspannung - unterer Grenzwert unterschritten Versorgungsspannung Spannung dauerhaft zu niedrig]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 40
Mileage: 61996 km
Date: 2018.12.16
Time: 11:34:34
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AB HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2203
Revision: -------- Serial number: 15041510001535
Coding: 0901000800087300EF000008080F00000001050000000000000000000000
Shop #: WSC 00066 790 07029
ASAM Dataset: EV_GatewConti 011020
ROD: EV_GatewConti_011_VW37.rod
VCID: 71BFD7A0E122FE4F615-8024
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0101
Serial number: 29150000777700055165
Coding: 30FFFF
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0057766
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000070043004
Coding: 5500000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB.rod
VCID: 34311EB4DEB08B674A3-8060
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 393 B HW: 5Q0 959 393 B
Component: TSG FS 020 0025
Serial number: 0805150605037L
Coding: 003013200000040000000000
ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 3E253C9CE0FC5137AC7-806A
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000001068660
Coding: 011000
1 Fault Found:
65588 - Motor for Window Regulator
B1487 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 44
Mileage: 65096 km
Date: 2019.01.02
Time: 19:14:34
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 0102
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_012_VW37.rod
VCID: 43D34D688B1E3CDFC39-8016
2 Faults Found:
12289 - Supply voltage
[Abschaltung wegen zu niedriger Versorgungsspannung Abschaltung aufgrund von Unterspannung (<5.5V für 3ms: KL50=0]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 37
Reset counter: 40
Mileage: 61996 km
Date: 2018.12.16
Time: 11:34:35
Motor status: 00
System status: Waiting for start request
Supply voltage: 5.50 V
Temperature: 15.0 °C
KFC: 30
KFA: 00 01
Environmental conditions: 20
uAdSensI_U1V2Filtered_gdu16: 1.20 V
uAdSensI_U5VFiltered_xdu16: 0.00000 V
uioUdNotFilt_xdu16: 5.34 V
uAdSensI_SwitchedKl30_xdu16: 5.31 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
26885 - Comfort limitation
C10D7 00 [008] - -
[Speicherinkonsistenz im Errorhandler]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Motor status: 00
Supply voltage: 0.00 V
Temperature: 80.0 °C
KFC: 69
KFA: 00 05
Environmental conditions: 21
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 392 B HW: 5Q0 959 392 B
Component: TSG BFS 020 0025
Serial number: 250415060507OE
ASAM Dataset: EV_DCUPasseSideEWMINKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 3D273B90EDFA4A2FB5D-8068
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000001126043
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 844 HW: 5G0 035 844
Component: MU-S-S-US 014 0655
Serial number: V7B01004150430
Coding: 02730200FF00000021220001001800001F0100140100010002
ASAM Dataset: EV_MUStd4CPASE 002040
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 6491AEF42ED05BE71A3-8030
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5G0 919 605 H HW: 5G0 919 605 H
Component: ABT_Std_Plus H60 0030
Serial number: VWZ8Z9RS501M9T
1 Fault Found:
0020 - Tuner for Satelite Radio
B11CF 53 [009] - Deactivated
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 174
Mileage: 11481 km
Date: 2017.08.24
Time: 08:04:39
Voltage terminal 30: 12.5 V
Satellite radio tuner status-Satellite radio antenna status: Electrical OK
Satellite radio tuner status-Channel selection for satellite radio: 0
Satellite radio tuner status-Audio Signal: Not available
Satellite radio tuner status-Antenna current: 0 mA
Satellite radio tuner status-Reception quality: Not available
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0564
Coding: 02730202C2821A017F1E06000000
Shop #: WSC 00066 790 00323
ASAM Dataset: EV_OCULowMQB 001003
ROD: EV_OCULowMQB.rod
End----------(Elapsed Time: 01:23, VBatt start/end: 12.2V/12.1V)-----------
Revision: 85H23---
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 64213 km
Date: 2018.12.30
Time: 07:37:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 64213 km
Date: 2018.12.30
Time: 07:37:01
1 Fault Found:
C102D 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 215
Mileage: 21847 km
Date: 2017.11.20
Time: 07:05:52
Coding: 030C0C
Revision: 00001K01
Coding: 0E4DDD
8 Faults Found:
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 228
Mileage: 15175 km
Date: 2017.09.17
Time: 13:51:58
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 228
Mileage: 15157 km
Date: 2017.09.17
Time: 12:39:23
Freeze Frame:
Fault Priority: 6
Fault Frequency: 24
Reset counter: 46
Mileage: 61996 km
Date: 2018.12.16
Time: 11:34:08
Occupant Detection:
Coding: 303138
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 0400
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 40
Mileage: 61996 km
Date: 2018.12.16
Time: 11:34:34
Alternator:
Coding: 30FFFF
Coding: 011000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 44
Mileage: 65096 km
Date: 2019.01.02
Time: 19:14:34
Coding: 0102
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 37
Reset counter: 40
Mileage: 61996 km
Date: 2018.12.16
Time: 11:34:35
Motor status: 00
KFC: 30
KFA: 00 01
C10D7 00 [008] - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Motor status: 00
KFC: 69
KFA: 00 05
Coding: 091000
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 174
Mileage: 11481 km
Date: 2017.08.24
Time: 08:04:39
