pbraunton
Hello:
Been a long time since i have posted on here, but I have found a 2005 Passat Tdi to replace the gas guzzler passat that we currently have
the Tdi passat has 198, XXX km's, the owner says the timing belt was done around 150,000 (have not seen the receipt but he has it), .....
what other things shoudl i bee looking at
here is what concerns me, ......
BSM
What does it sound like?, is it obvious when it is on it's way out? or starting to make noise, i know it cost $$ to fix this but if it is ok now, then i can get it done with the next TB job...., but I have no idea what it would sound slike if it were going bad??.......
Oil used
Does the cam wearing issues apply to this engine, (I forgot to look at what engine code it is) is there only one for the 04/05 passats??? and what is the engine/ oil i should be watching out for?? (don't want this to turn into a debate though LOL)
glow plugs - i thought i saw something about a glow plug recall, and reflash?.......is it important to have this done, and if it is not done how much, "RISK" is there for me to take it into the dealer to get it done???
as far as the car, it is in really good shape, few small stone chips in the hood, ...........and i am going to take it to a "guru" this afternoon, to have them take a look.....
anything else besides the normal car stuff (rust, brakes, A/C, heater, tires normal wear and tear) that i should be looking out for????
thay are asking $9,500.......cert and E-tested, he is the second owner, ......
thanks ALL!!!
BSM
Oil used
thanks ALL!!!
