efb91 said:
I am calling the cabin fan the one inside the cabin, that blows in your face.
The radiator fan towards the passenger side of the car is the only fan that I see running. It starts immediately when I start the engine, and when I turn the A/C on, I can see no visible change in the working fan's speed, and of course, the second fan towards the driver's side doesn't turn on at all.
I've already checked the charge on the system; I thought that after 162k maybe there was a leak and I needed to recharge the system. The system didn't need a charge at all; I didn't really think there was a leak to begin with, I was just hoping it was something simple.
Thank you, by the way, for helping me with this, Dan. I really can't afford to pay the dealership to do it, so I really appreciate you helping me out.
efb,
You are welcome.
So something is causing your fans to be requested to run continuously, but is not allowing your AC clutch to engage.
Can you tell if the fan is in fast speed or slow? It can be hard to tell if you are not familiar with them - and most people are not.
The slow speed fans can be requested by:
1) AC on with normal pressure.(would normally also request clutch on).
2) radiator thermoswitch on (would not impact AC clutch operation).
3) ECU high temperature (MAY turn off the clutch.)
If AC pressure sensed is high, it will run your fans continuously on high any time the key is on.
Go back to post #1, read through the AC troubleshooting guides, find the photos of the high pressure sensor and unplug it. See if this turns your fans off. If it does, and your high side pressure is less than the value specified in the table (which it will be unless you have grossly overfilled the system, since the clutch is not engaging), then you have found a second problem (besides the broken fan.)
