Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Audi SUVs (Q7 & Q5) and other V6 TDIs
Audi SUVs (Q7 & Q5) and other V6 TDIs Discussions area for Audi Q7 and Q5 TDI (2009+ in Canada & the US) as well as others with the V6 TDI such as the A6, A7 and A8 sedans.
Old May 27th, 2019, 06:50   #31
Radman
I think with your set-up the smoke is there to stay unfortunately....
2014 Audi A6 TDI, Unitronic Tuned
2014 Touareg TDI, Unitronic Tuned
Radman is offline   Reply With Quote
Old May 30th, 2019, 23:29   #32
DieselDeeds
Thatís awesome man! I am stage 2+ plus and I donít blow any black smoke; Iím also catless. Iíve only once noticed a smalllll amount of black smoke when I floored it a few weeks ago and the smoke only came out when I stepped on the pedal- then disappeared for the rest of the pull.
Just to contribute my personal fuel routines to this thread: I donít use biodiesel; I typically use 76, shell, or chevron diesel and I also add some Stanadyne performance diesel additive on every fill up. My dad uses Stanadyne on his diesel and swears by it. Try regular diesel #2 and some diesel additive. Glad you like the recent mods man!
DieselDeeds is offline   Reply With Quote
Old May 31st, 2019, 09:08   #33
Huskies2710
Huskies2710's Avatar
Smoke has definitely lightened up. The shop did not block off the EGR. It has been tuned out. I'm wondering if a block off plate will help the smoke?
I'm going to go the Diesel #2 route exclusively. Currently we have Hotshot Diesel Extreme additive because we were dosing a bit of that in the Mercedes CDI once a month. I'll check out the Standadyne. I know VW was recommending it.
As far as the car, I can't believe it runs even smoother then it did after the first tune and DPF still in. I cannot feel any shifts under WOT throttle with the new Stage 2 ECU tune and updated TCU tune. This past weekend did a trip 720 miles completed on one fill up. There were about 60 miles of stop and go thrown in. I think I could do 800 miles on a tank if it was all highway.
Huskies2710 is online now   Reply With Quote
Old May 31st, 2019, 18:42   #34
2014 A6
Stanadyne all the way. Blue flavor.
2014 A6 is online now   Reply With Quote
Old June 1st, 2019, 00:42   #35
DieselDeeds
Thatís awesome man. I think I have the EGR block off plate on my Q5 so that might be one of the reasons I donít get as much smoke- to be honest though, I have no idea if thatís why. I do know that the mileage is insane on these diesels with the deletes. Iím considering making a road trip to the Chicago area with my wife this summer to get that TCU tune done! It sounds like itís worth it if itís reliable. Glad to hear your exhaust smoke is getting better- Keep us updated!
Old Today, 07:59   #36
Huskies2710
Well learning that once you start tinkering you might run into some problems. Noticed after work yesterday I had a clear liquid that was crystallizing under the car. Drip was fairly consistent. To this morning seeing it really dried up on the undertray. Is this an Adblue leak? We only did a dpf delete. Waiting to hear back from the shop. No warning lights thought the Adblue was tuned out.
How corrosive is this stuff should I be washing the bottom of the car off in the meantime? Debating to jack the car up and pull the undertray off while I wait. Not what I want to be doing on my day off of work :/
Old Today, 08:43   #37
Radman
Looks like DEF fluid leaking from the DEF injector port. Did they not delete the DEF with your tune?
Wash it off with a hose.
Old Today, 10:07   #38
Huskies2710
The kit was a Buzzken DPF delete. It does not delete the EGR or DEF.
https://www.tunemyeuro.com/dpf-delete-for-audi-q5-a6/
From my understanding we just tuned out the EGR/DEF. I've been wondering if keeping the EGR intact has allowed the car to warm up as normal but also creates more smoke. I have had no loss of heat when running the heater which I felt was odd. At the same time this could be causing more smoke to be emitted as well?
Seeing as I'm not the most mechanically inclined. It took me a bit to get the under tray off but I have finally gotten there after picking up the right tools. Trying to be proactive. Here is what I found.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Huskies2710
2016 A6 TDI limp mode ykaudi Audi SUVs (Q7 & Q5) and other V6 TDIs 17 April 25th, 2019 08:11
A6 2014 prestige Malone Stage 2 tune LECDO TDI Power Enhancements 7 March 17th, 2019 20:46
2016 A6 Allroad Avant Tailgate trim removal FlyingFin Audi SUVs (Q7 & Q5) and other V6 TDIs 0 June 14th, 2018 12:08
Prices Paid for 'New' 2016 A6 (post-fix) moosekevin Dieselgate - VW Group Emission Scandal 10 January 26th, 2018 15:36
Audi A6 1.9TDi '98 81kW poor power until 3 krpm [Video] [VAGCom Log] Arturasz TDI 101 2 October 5th, 2012 05:37
Page generated in 0.16162 seconds with 12 queries
[Output: 90.55 Kb. compressed to 78.83 Kb. by saving 11.73 Kb. (12.95%)]
