Old November 8th, 2018, 16:07   #1
crustodd
Default Kerma Tune/ Polar FIS display
Hello all,
So, I decided to go with the Kerma ECU/DSG tunes on my JSW. I felt keeping all of the emissions junk in place might be better off for now. I elected to get the Polar FIS display unit included. What would be the most desireable functions to have the display screens show? ALL INFO APPRECIATED!!! This is a daily driver/200 miles a day. Tune purchased for MPG improvements. Polar for monitoring functions for longevity.
Thanks,
T~
crustodd is offline   Reply With Quote
Old November 8th, 2018, 17:31   #2
calimustang
Subscribed to this. I def would like to know also abt Polar FIS
2011 JSW TDI retired and buyback, gone to heaven. almost 300k miles.
2015 Passat TDI with 22k miles on 5/6/2018, completely stock. Black exterior and black interior, 5% tints all around. Now 32k on 9/18/2018.
2014 JSW TDI bought used on 8/26/2018 with 27k miles, white with cornsilk interior. 5% tints, all stock.
calimustang is offline   Reply With Quote
Old November 8th, 2018, 17:38   #3
Owain@malonetuning
boost and EGT would be ideal. Boost to make sure things are operating properly, EGT to keep an eye on regens and general temps during aggressive driving.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Old November 8th, 2018, 17:39   #4
calimustang
For EGT/Boost alone.... I have P3 gauge. Been happy with it for years.
Old November 9th, 2018, 04:48   #5
ksing44
I also have the P3Cars gauge and it's all I need. The Polar has all kinds of other data that can be displayed, but for me monitoring EGT for information about regen activity and being able to quickly see and clear codes is all I think I need. At first I watched boost to see what was going on, but it's always the same thing and not really very informative about the operation of the car. I think monitoring EGT is essential for owning one of these cars. It's also easy to install and doesn't cause any issues. To me, the Polar seems to be a bit over the top.
I think VAG-COM is another essential tool for getting detailed information about the car and also for tweaking some of the settings to your preferences, e.g., for me that's no auto lock, windows up and down with remote, no honk with locking the doors, no seatbelt chime or light, fogs on without headlights, and no DRLs. It also helped with settings when I got LED taillights and to lower the pressure for my TPMS system because I like my tires on the softer side.
2010 Golf TDI - Blue (BGM), 4-Dr, 6-M, Sunroof, Xenon, Dynaudio, Nav (RNS-510), Euro light switch, 9W7 BT, R Tinted LED Tail Lights, Monte Carlo 17" x 7.5" ET47 Wheels, 235/45/17 Tires, P3Cars Digital Interface, Sonniboy sunshades, CP3 HPFP - 11/8/2016 @ 139,848 miles, The Fix - 9/27/17 @153,289 miles
Flickr slideshow
ksing44 is offline   Reply With Quote
Old November 9th, 2018, 06:02   #6
calimustang
Ohhh ksing44, I need the link for no DRL’s and etc. I have VCDS myself. Just got an 2014 JSW with 27k 2 months ago out of an 2011 JSW with nearly 300k miles.
Old November 9th, 2018, 06:26   #7
ksing44
Below are links to different versions of the tweaks. The golfmk6 forum was how I got the information. You might have to sign in at golfmk6. I also downloaded the pdf document from that website.
Tweaks from Ross Tech
Tweaks listed at golfmk6
Link to tweaks in a pdf document from golfmk6
Flickr slideshow
Old November 9th, 2018, 07:27   #8
calimustang
Ksing44, you rock! Many thanks
Old November 9th, 2018, 12:55   #9
Dirty
I have the Kerma tune and the polar FIS. I am very happy with both. The data I display are mostly related to emissions functions. DPF status, Miles since last regen, EGT, DPF temps, Soot load etc.
Dirty is offline   Reply With Quote
Old November 9th, 2018, 18:44   #10
ItsPhilD
ItsPhilD's Avatar
I use Carista to change things like locks, DRL, etc. Works great.
Sent from my iPad using Tapatalk
ItsPhilD is offline   Reply With Quote
Old November 9th, 2018, 21:54   #11
Wilkins
Fuel Economy: 4.6/5.6 - 5.3/6.7
Don’t forget the most important one of all - speed. The Polar FIS provides a very accurate digital speedometer which will tell you that the cluster reads exactly 6 km/hr high at 100 km/ hr. No more guessing!
I run 7 screens, more than I need. Mostly I use 1) speed, miles since regen, no of regens requested, soot load, 2)speed, egt, DPF in, DPF out, 3) speed, atmos press, requested boost, actual boost, 4)speed, coolant temp, oil temp, fuel temp. Only oil temp doesn’t work LOL. Something about not having a sensor.
I’m having some fun now post fix sorting out the boost which seems to have changed, or maybe it is the latest 5.7beta I downloaded when the fix was installed. Presently I’m running off the diagnostic feed and see about a 1psi offset requested vs actual when the engine is cold, which goes away as it warms up. I’m pretty sure that wasn’t there pre fix. I will post something when I get a bit more info.
2005 Jetta Wagon: Evo skid plate, Kerma Tune, Moog VR6 front springs, Koni Reds, Jeff's HID's, Upgraded door switches!. MKVI: Containflo+Pureflo, Rear Tiggy springs and B6 Billies, Xenon w LED, AFS, 087T BCM
Wilkins is offline   Reply With Quote
Polar FIS+ Demo3 VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 99 November 14th, 2018 09:14
Polar fis eyyopomps Private TDI Items for Sale/Wanted 0 February 2nd, 2017 04:32
FS: Polar FIS sootchucker Private TDI Items for Sale/Wanted 7 January 30th, 2017 06:25
Fs polar fis advanced dashboard display md $200 BlackJettaTdiGuy Private TDI Items for Sale/Wanted 1 January 25th, 2017 22:57
Full FIS Display upgrade from Half FIS fuzion Upgrades (non TDI Engine related) 2 September 28th, 2006 03:58
Page generated in 0.16741 seconds with 12 queries
[Output: 104.23 Kb. compressed to 88.56 Kb. by saving 15.67 Kb. (15.03%)]
