Just returned from an alignment appointment for my 2015 tdi Golf Sportwagon and am being told that due to a variance between my left and right caster measurements, it is likely that my left control arm is bent and will need to be replaced. No visual damage/bend is noticeable.
I am aware that there is no stock caster adjustment and I am not an alignment specialist, could somebody let me know if my left/right castor variance of 0.65 is problematic and needs to be addressed? if so, is a control arm replacement the only way to correct it. Both caster measurements are withing the acceptable range but are off by .65 degrees from each other
CASTER Min-Max 7.07-8.07
Caster Left 7.78
Caster Right 7.13
If the variance needs to be addressed, is there cheaper aftermarket options to make the caster adjustable rather then spending $440 (CAD) for a control arm and the 2 hours labor to replace it?
Thanks you in advance!!
Matthew
Sorry having difficulty posting the photo of alignment measurements using the forum tools. the photo can be seen HERE
Caster Left 7.78
Caster Right 7.13
Matthew
