danimal17
OK, so it seems like I am going to go in this direction:
Moog Front and rears from RockAuto
Bilstein TC front and rear
Metalnerd 2" lift
Spacers for front (stacked 2 high)
Winter tire setup is going to be 205/70/15 on stock steelies
My current ride height is stock:
Front sits at an unloaded height of 26.5"
Rear unloaded is 27.75"
Judging by other setups, I should be somewhere in the 29-30" ground to fender clearance correct?
And I just want to verify the Bilstein set part number-VNE4575_BNE2917
G Men 08, so you are using the Metalnerd 2" lift and spacers in the front. Why do you need the spacers and do you have a part number for those? I have the same car as you and want to do the same thing.
