TDINJ
Car is a 2005 MKIV PD Jetta. After prolonged periods of driving, especially when the air temp is high, I experience long crank times (about 3 to 4 seconds) to start the engine if I've stopped for something and get back in to turn on the car.
I've tested the lift pump recently, it works. I have no CEL/codes, and the car starts right up instanly in the morning, with the air temp cool or hot.
Could it be a MAF issue? It has the same one since new, now at about 164,000 miles. I don't think there are any air/fuel leaks as the car isn't leaking fuel that I can tell.
Any suggestions? Thanks.
