Norm0770
I know there is no word on a fix yet from VW, but here are my thoughts: For the newer cars and Passats that have the urea injection system the fix could or should be pretty straight forward: increase the frequency/amount of urea used and shorten the service cycles for urea refills. I think the reason the VW with the Ad-Blue system failed in the independent testing is because not enough urea was being used to scrub the exhaust (probably because they wanted the urea fill to correspond with the scheduled oil changes).
Cars like mine however are a different story. We know a software update will allow the cars to meet the emissions standards, but the effect on performance and mileage will almost certainly be detrimental. Also there are questions about how the other emissions components will fare as a result of running this richer mode, which lowers NOx, lowers operating temperature, but increases CO2 and fuel consumption. Diesel particulate filters and the EGR and EGR-filter will certainly fail faster. So it seems a software only fix won’t be the answer.
Even if the software only fix can meet the standards without affecting the durability of the parts the cars were advertised as having 140hp, 236 lb-ft of torque and getting 40 mpg on the highway. If any of these parameters fall short they are guilty of false advertising. A few tears ago Mazda bought back RX-8s for a 5% hp discrepancy.
Adding a urea injection system to all of the 2009-2014 Golfs and Jettas would require a large, costly engineering effort to retrofit the systems to fit in the car: A 6 gallon tank for the urea solution, sensors before and after the DPF and the injectors themselves. This seems cost prohibitive to me, as they may not be able to use much of the exhaust system that is in place, relegating it to the recycling bin. After this kind of retrofit the EPA will require them to warranty the new exhaust system to the federal 8 year 80000 mile standard, without the benefit of any real world extended testing… A buyback may actually be cheaper.
I'm certainly not holding my breath for a buyback though...
