davidm2232
I am swapping out my broken 01m for a used 02j. I have done all the under dash wiring inclduing replacing the 175 relay with a 53 relay. I have also connected the reverse light switch. the only other wiring i have to do is to change the connections in the ecu/tcu for cruise. I need a pinout/diagram of the ecu connector to determine what pin 66 is that i need to put the wire from pin 19 for the wire coming from the TCU/ 53 relay. Thanks so much. Any suggestions for changes to that setup would be appreaciated. I am using the wiring instructuions found at:http://www.instructables.com/id/VW-Beetle-Golf-Jetta-Automatic-to-5-Speed-Swap/step2/Remove-and-rewire/
