Old September 23rd, 2015, 16:59   #16
Drivbiwire
Zehntes Jahr der Veteran
Fuel Economy: Who cares, it's a diesel!
Originally Posted by Wankel7 View Post
Can't beat first hand experience!
Could you expand on why you feel the lower stage / flow was a mistake?
In an untuned car would would injectors set to stage 1 make the same power as injectors set to stage 3?
Stage 3 give more fueling potential, but a tune expands that by using more available range of control than a stock ECU allows.
Like I have mentioned, you should go with a Stage 3 and modified Pilot...
Specializing in Injectors for CRI, CR, PD, VE, IDI VW, Audi, MB, SEAT and Skoda Diesel engines.
Offical Importer, Distributor and Installer for Fratelli Bosio, S.R.L. North America
Quotes and Pricing for TDI Injectors
Drivbiwire is offline   Reply With Quote
Old February 23rd, 2018, 08:57   #17
Nevada_TDI
I used to have .205 nozzles set at Stage 1 and a 18 PSI Stage 3 tune. My clutch had 100k miles on it when I did this upgrade, and over another 100k miles later my clutch still did not slip. I did not beat on my clutch, which was a big factor in the life of my clutch.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Previous Diesel: 1983 Rabbit Diesel
Old February 23rd, 2018, 10:09   #18
Scott02
TDI(s): Too Many
Fuel Economy: 51/45/41
For ALH cars... 99.5-01 cars have a LUK clutch that holds more torque than the 02-03 Sachs clutch.
2015 GSW DSG - 27kmi, Kerma engine tune
2011 JSW DSG - 160kmi, Malone DSG tune - Buyback done
03 Jetta Wagon TDI 5MT - 175kmi, 2.5"F 2"R lift, 215/75r15 tires, self tuned
02 allroad TDI 6MT - 150kmi, current project, getting a BSM deleted BHW and euro TDI geared 01E quattro
Scott02 is offline   Reply With Quote
Old February 23rd, 2018, 10:12   #19
Scott02
TDI(s): Too Many
To the OP, one must be careful when asking for recommendations about clutch slip or not. Big differences in the clutch can be seen year to year even in the same body style / family.
A custom tune for a stock nozzle, stock exhaust, 10mm pump can easily slip a stock Sachs clutch of an 02-03 car.
Old February 23rd, 2018, 10:17   #20
h4vok
h4vok's Avatar
Fuel Economy: 35 to 50
With my DLC520s I have them at stage 1. I have my tune hold off on fuel and boost below 2k rpm to stock levels, but once it gets up to about 2300rpm I have it at 17psi and 45mg of fuel. Pump voltage is scaled pretty close to the euro car so the 45mg should be pretty accurate might be more like 50mg though. Still stock clutch at 160k and it does not slip even in the cold. If I were to get more aggressive down low it will slip in 5th, but I have tuned that out. It is a nice little increase probably like 110hp and 190tq.
DLC520, Mufflerectomy, tuned, more linked below
My car thread
h4vok is offline   Reply With Quote
Old February 23rd, 2018, 10:29   #21
Scott02
TDI(s): Too Many
On an 03, stock nozzles, stock pump map, getting (not asking for) 51mg anywhere below 3500rpm asks for clutch slip on cold days. NE Ohio cold, not Florida cold.
EDIT: Just looked at tune. 44mg at 2500rpm. So your DLC520 0.205mm nozzles are getting no more power than stock nozzles can. 02-03 ALH cars are very clutch limited. Stock is 37mg max anywhere in the torque limiter.
Old February 23rd, 2018, 18:11   #22
h4vok
h4vok's Avatar
Ya basically like a malone stage 1.5 is what my tune is like. Stock nozzles can provide the fuel I am requesting, but the dlc520 can do it at a shorter duration. When I get a vr6 clutch I will let the fuel rip.
My car thread
Old February 23rd, 2018, 19:03   #23
[486]
TDI(s): 02 golf ALH
mine held everything that pp764s would put out, 10mm pump, burning clean with compound turbos
yours was probably just worn out
Old February 28th, 2018, 00:17   #24
Jukums
Drivbiwire
Checked you page and don't understand, how you can get more fuel from the same size nozzle. Only what there can be done, is changing 1 stage and 2 stage opening pressures, but I don't think, that it will give +20% more fuel. Could you please explain that ?
Audi 80 B4 1.9TDI Power figures: unknown
0-402 best time 13.3sec trap speed 179km/h
Engine: Building at the moment.
http://www.tdr.lv/audi-80-b4-jukums/
Jukums is offline   Reply With Quote
P0401 - EGR insufficient flow with Malone stage 2 emerscape VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 21 October 2nd, 2015 17:41
DLC520 Nozzles for Fuel economy alhdude TDI Fuel Economy 14 February 1st, 2015 17:31
Colt stage 3 in my ALH vwdsmguy TDI Power Enhancements 17 May 12th, 2013 18:48
ALH parts. EGR valve, Mass air flow sensor, Starter TDIswanted Private TDI Items for Sale/Wanted 1 January 31st, 2013 20:09
Bosio PowerPlus Stage 2 764 - looking for hole diameter or flow rates T3-UN1 TDI Power Enhancements 12 October 25th, 2011 03:02
Page generated in 0.18043 seconds with 13 queries
[Output: 98.97 Kb. compressed to 85.25 Kb. by saving 13.72 Kb. (13.86%)]
