mrfiat
- Joined
- Mar 24, 2008
- Location
- Los Ranchos, NM
- TDI
- 2003 Jetta TDI (Reflex Silver) , 2003 Jetta TDI Wagon (Black)
I'm on a road trip from Albuquerque to Seattle. 44.7 mpg from Albuquerque to SLC! Diesel is way cheaper than gas here in SLC. $2.07 a gallon as opposed to $2.80. I thought I noticed some clutch slippage on my 2003 ALH sedan back home, but I thought maybe it was the traction control. My sedan has upgraded nozzles and a Kerma tune. VNT15. Well, on the way to SLC, I noticed a couple of time when I floored in at about 2200 rpm in 5th, the revs would go up, but not the speed. :-( I duplicated it again in 2nd gear. The PO claimed the clutch was replaced like 15,000 miles ago, but maybe not. (no docs to prove it was done) Is this slippage anything to be concerned about regarding my round trip to Seattle? I'm assuming the thought is, just don't floor it. The car has 217,000 miles on it. Do I just need to install an upgraded clutch when I get back home? Another option is having a guru install an upgraded clutch in Seattle since I will be there for 2 weeks. Thanks.
