SilverWagon
Engine swap now clutch slipping out of gear..
I recently had my engine swapped, after the original failed, by a mechanic that lives 300 miles away. I was traveling when the engine failed... When he swapped the engine he used the oem flywheel that was attached and switched the clutch to oem when the clutch didn't match up with it. After I test drove it and told him the clutch didn't feel right he told me what he did. I told him the car had a stage 2 south bend clutch SBK70316F-HD-O with about 30k miles on it so he switched all back to the southbend clutch assembly... I think....
Anyways, I drove it 700 miles and yesterday and transmission started acting up. I'm thinking the clutch started to slip.
I was driving on the freeway, maintaining 75, and the engine just started to rev higher while making a reving sound that was different from engine noise. It didn't sound like grinding but it could be. The car just coasted while I took the stick out of gear and put it back into gear. It happened 2 more times that day while I drove around town.
I called the mechanic and he said he would swap the clutch assembly for the oem assembly he got with the used engine. I don't think I want to risk driving it until I know what is wrong with it. I have a guy coming Wednesday to take a look. Any ideas?
