nathanso
Are 2016 Golf R springs compatible with my 2015 GSW TDI? If yes, what could I expect from the swap?
Went with GTI Mk7 springs and Bilsteins on my 2019 Alltrack. Lowered the car to stock GTI height and handling and ride both greatly improved. Thinking about putting a 24mm rear sway bar to neutralize a bit of the understeer.My current setup is MK7 GTI springs front and stock MK4 Golf springs rear paired with Koni's. With stock suspension, the car measured 27 1/8" front and 27 1/4" rear ground to fender. With the current springs and struts/shocks, it measures 25 3/4" front and 26" rear. All OE springs and a mild/reasonable drop. It rides and handles much better than stock.
H&R RSB is a great upgrade on an Alltrack, just plan on moog end links as the OEM fasteners get crusty and cant be reused.Went with GTI Mk7 springs and Bilsteins on my 2019 Alltrack. Lowered the car to stock GTI height and handling and ride both greatly improved. Thinking about putting a 24mm rear sway bar to neutralize a bit of the understeer.
