Isackn
Hello there,
I'm trying to resurrect a 2001 TDI ALH 5 speed that had been sitting for approx 4-5 years without being started and possibly dead battery for 4-5 years.
Currently I am having a no start issue,
Things ive done ////
-Timing belt replacement (timing was checked, then triple checked, then checked again)
-Drained out old diesel
-Fuel system flush
-Fuel filter replaced
-Primed injector pump
-Tested relay 109 (works well)
-Oil change
-New injector Nozzles
-Fresh IP
-IP solenoid functional
Things I have yet to look into further///
-Immobilizer
-ECU
Current symptoms///
-Possible low fuel spillage when bleeding injectors.
Thus engine turns over, just no start.
My thoughts, the injection pump isn't pumping out enough fuel to injectors. Possibly caused by #3 injector needle sensor?
Ive been a long time Forum creeper, but never really been this stumped before. I hope maybe someone can help me out!! Thanks!
-Fuel system flush
-Oil change
-Fresh IP
-Immobilizer
-ECU
Current symptoms///
