ericas_beetle
Hiya,
After six great years with no leaks, I noticed water coming out around the vanity mirror lamp on the passenger side of my beetle today. Last time I had a leak it actually turned out not to be a clogged drain, but a flaw in the windscreen gasket seal right over the passenger side. We added a whole bunch of 3m window weld and stopped it cold.
I remember at that time checking the drain lines since the headliner was pulled out and we ran rinse water through them as well as poked down with a long piece of weed eater line.
I tried shoving line down it again to see if that was the source of the leak this time, and it doesn't seem to be going through all the way, so I'm thinking maybe it got sludged up. Is there a way to snake it up from the bottom end on a beetle? I'm not even sure where the downstream end of it is. Does it drain into that space under the plastic cowl under the windshield wipers? Or is the end farther down, like behind the inner fender liner behind the wheel? I really don't want to go back to a stinky mildew car again
Thanks!
Thanks!
