zivatar
My'96 B4 sat for two years without running. Before it sat, it had intermittent starting problems due (I think) to ignition switch problems. Then I lost the key, which is why it sat. (Dummy) Just had a new key made by locksmith from door cylinder, replaced dead battery, much to my surprise it started right away, ran, albeit with much smoke.
Does anyone have suggestions about what I should do now? I need to replace at least one of the tires, maybe more, so I won't be driving it anywhere in the short run, but what else should I do to get it going again, given that it sat for so long?
