ChadS
Hi Gang,
My wife has a 2001 TDI Golf automatic that is driving us crazy. It has 76k miles on it now and ever since the timing belt was changed at around 55k miles it has been difficult to start on a cool North Carolina morning (around 60 degrees F). We have had it back to the dealership twice and both times the timing has been "within range". The engine seems to turn over slower than my Dad's TDI Jetta 5sp but the tech's have load-tested the starter and I have cleaned all of the engine/chasis grounds that I can find...no improvement. After the first start of the day the car starts easily. The glow plugs are working when the temps are colder and the car will actually start better at 32 degrees than it will at 60 degrees.
I still suspect the timing - is there static and dynamic timing on these engines and are both set using the scan tool? I see a procedure in the Bentley manual but the TDI is a little different than our other diesels (pickup/tractor)....I am thinking that the static timing may be retarded slightly after reading some other posts, am I on the right track?
Thanks,
Chad
Thanks,
Chad
