2015 SEL Fuel Filter Housing Bolts
Chaz13
NY
2015 Passat SEL
Hi
I was going to change my fuel filter and none of my triple square, torx, torx ip or hex metric or sae fit. Any one know what it could be? it has 6 points of a torx the T15 is to small T20 too big, the 15ip fits better but still too loose, striped the head on the first nut I tried.
Jetta_Pilot
West Hill, Ont.
I changed my fuel filter without having any problems using the TORX bits I had on hand!
What nut are you talking about?
Chaz13
NY
2015 Passat SEL
Here is a picture of it, like I saidd the T15 bit is too small the T15ip fits better but still too small and the T20 is too large.
[/URL][/IMG]
Jetta_Pilot
West Hill, Ont.
The T20 is a perfect fit!
If you can't move them, try a vise grip on the bolt head.
740GLE
NH
looks very standard torx to me.
tadawson
Lewisville, TX
2013 Passat TDI SEL, 2015 Passat TDI SEL
Not sure what the OP's Torx bits are, but I have found some of the offshore cheapies to be incorrectly sized, and found better ones to fit just fine . . . If you have access to more than one T20, you might try another one to be certain . . .
jrm
Oregon
2013 Passat SE with nav (totaled)
how did you get photobucket to work? they haven't allowed viewing of anyone's pictures in over a year :eek:
