Old April 10th, 2018, 08:49   #1
Henrick
Default Motorkote - the US product in a TDI?
Greetings US guys,
a quick question - has anyone of you heard or used Motorkote Hyper Lubricant in an internal combustion engine?
I watched this video and it seems that thewear is actually reduced: https://www.youtube.com/watch?v=88vwUwa3igQ
Since this doesn't look like a snake oil, I am considering to try to use this product in a TDI.
I did some googling and seems that this product is available only in US, unfortunately.
Thoughts? Comments? Feedback?
Henrick is offline   Reply With Quote
Old April 10th, 2018, 11:30   #2
belome
Fuel Economy: 47'ish
A solution in search of a problem???
The only thing I can pass is a fuel stop, but I'm OK with that.
My claim to fame - I was banned from VWVortex!
belome is offline   Reply With Quote
Old April 10th, 2018, 14:26   #3
Henrick
No, it's more like "it won't do any harm anyway" idea.
Would love to see how this works in a PD motors which suffer premature cam wear though
Old April 11th, 2018, 04:30   #4
GreenLantern_TDI
GreenLantern_TDI's Avatar
Fuel Economy: Mid 40s
Kinda like Archoil 9100. BITOG site shows many advising against playing garage chemist. Does it work? Maybe. Does Archoil work? Maybe. Can you also make Meth in your garage? Sure you can. But should you?.....
2015 Golf SEL. Frost Heater. Ares Skid Plate. Fumoto Valve. PentoIII.
GreenLantern_TDI is offline   Reply With Quote
Old April 15th, 2018, 08:49   #5
James & Son
TDI(s): 2006 Jetta
A 9% mix is 93,750 parts per million. How much is carrier and how much solid particles. likely a mix of nano solid metals of some kind along with a carrier that has an affinity for metal. Surely someone at BITOG has done a oil analysis on this.
Edit, here is an example; https://www.sciencedirect.com/scienc...1836391600012X
James & Son is offline   Reply With Quote
Old April 15th, 2018, 12:27   #6
Henrick
Well, that artice doesn't say it's Motorkote.
It may or may not have different ingridients.
Wonder if there was UOA done for specifically that stuff.
Old April 15th, 2018, 12:43   #7
Henrick
I found a few VOAs/UOAs and they show absolutely nothing. The ingridients must be some other than those tested in a chap UOA test
Old April 16th, 2018, 04:06   #8
turbobrick240
turbobrick240's Avatar
I envision some guy in a garage filling those little bottles from a drum of Ashland 30W. Also, that guy's testing apparatus/procedure isn't worth squat.
Making chalk mark on generator- $1
Knowing where to make mark- $9,999
Old April 16th, 2018, 11:51   #9
Henrick
Which guy you are referring to?
Old April 16th, 2018, 19:42   #10
turbobrick240
Both guys. The one selling the motorkote snake oil, and the one rubbing rocks together and calling it science.
Old April 18th, 2018, 22:15   #11
Ol'Rattler
Ol'Rattler's Avatar
The reason PD cams have wear issues is because the design is fragile, not because of the lubricating properties of the oil used. Unless Motorkote has little tiny engineers in it that redesign and re-manufacture your engine while you drive, the only thing it will do is make your wallet lighter.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old April 18th, 2018, 22:27   #12
Ol'Rattler
Ol'Rattler's Avatar
I found a few VOAs/UOAs and they show absolutely nothing. The ingridhttps://www.youtube.com/watch?v=XliL3qN1njAients must be some other than those tested in a chap UOA test
Why would a UOA test for the ingredients of something that doesn't belong in your oil? Imagination probably isn't a tested for ingredient either.
Yet another completely believable endorsement.
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old Yesterday, 11:27   #13
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2017 to end of April 2018
Completely believable from someone paid to read a script !
All interior bulbs to LED. Several VCDS modifications. Darker window tint. EVO skid-plate. Malone Stage 2, Winpower Projector headlights. Angel eyes.LED DRL's.24mm H&R rear sway bar.
Motorkote Dragracerzzz Fuels & Lubricants 9 May 27th, 2014 09:46
Tried Motorkote for the first time yakfish Fuels & Lubricants 30 January 23rd, 2014 15:57
Anyone using Motorkote? jnapier TDI Fuel Economy 2 March 24th, 2011 15:46
Any one used Motorkote TDIx2 Fuels & Lubricants 33 October 12th, 2007 09:01
MotorKote 100 -- What do you think?? jrbtdi Fuels & Lubricants 8 December 12th, 2002 19:38
Page generated in 0.13411 seconds with 12 queries
[Output: 113.48 Kb. compressed to 94.88 Kb. by saving 18.60 Kb. (16.39%)]
