Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
View Poll Results: 2015 Jetta Rattles /w less than 10k mi
Dash Rattle (Heater box) 5 11.63%
Dash and Steering Column Rattles 13 30.23%
Other rattles 9 20.93%
None 16 37.21%
Voters: 43. You may not vote on this poll
Old March 28th, 2016, 12:20   #46
atifvw
atifvw's Avatar
Mine rattles somewhere in the dash, at low rpms when cold, I'm at 19000 kms, I think its due to higher engine vibration during warm up period. Wife's Golf wagon way more smoother, absolutely no rattling, way better built. Does'nt bother me that much, I'm hoping it'll go away once the engine is broken in properly. The reason I say that is when I push it to higher rpms between the gears [Italian tune up] the rattling goes away. Hope this helps.
2015 Jetta TDI Sport 6spd Manual - His - SOLD
2008 Grand Cherokeek Diesel Da Beast...lots to list.
2015 Golf Sport Wagon TDI Highline/Pan Roof/Nav 6spd Manual - Hers
Retired TDI's: Lots to list
atifvw is offline   Reply With Quote
Old March 29th, 2016, 05:02   #47
FVWVWF
FVWVWF's Avatar
It wont go away....I've had and still have it. Had it fixed...came back....had it fixed again, still came back after a few weeks. Hopefully you are luckier with your dealership.
FVWVWF is offline   Reply With Quote
Old March 29th, 2016, 09:40   #48
IAmTodd
IAmTodd's Avatar
Sadly I think you're right. I had mine fixed last November, stored the car for the winter, and now the rattle is back. Not nearly as bad as it was in the fall but I hear it every now and then. I'm due for my one year service next month so that will be on the fix it list.
And I still have a clicking door panel that the dealer wouldn't touch and I can't track down.
IAmTodd is offline   Reply With Quote
Old March 13th, 2018, 19:13   #49
CTD_Chevrolet
CTD_Chevrolet's Avatar
Fuel Economy: 2015:43 2002:38 mpg, 51 max
This has been driving me absolutely insane and when I googled it awhile back I couldn't find anything. I just ecstatically ran outside and shoved my hand under the hood and the bolt is missing. I was starting to come to terms with driving with the radio cranked.
'15 Jetta S DSG - 30% tint, stickers
'02 Jetta 5 spd - 17/22, Race 520s, 11mm pump, ARP studs, 3" straight pipe, SBC Stage 2 Endurance w/secret sauce plate and 14lb SMF, Kerma Tuning, tons of stickers
'95 Chevy K2500 Brodozer - P Pump Cummins, Dana 60, etc, most stickers
CTD_Chevrolet is offline   Reply With Quote
Old April 16th, 2018, 06:08   #50
carnotgas
carnotgas's Avatar
TDI(s): 2015 Jetta
Fuel Economy: Very Good
Default Fixed, Thank You
I would like to thank everyone who contributed to this thread. I found the heater box screw to be loose and it would not tighten. The replacement screw part WHT004564 has a larger diameter and fit tightly. The clamp inside the car was contacting the heater box which I rotated. The rattle is gone. Without the information in this thread it might have been impossible to ever find the cause since it only happened under driving conditions. THANKS TO THE TDI CLUB AND IT'S MEMBERS!
2015 Jetta S TDI Sedan, Black, Automated Dual Clutch Constant Mesh Gearbox
Avatar: Never Forget
carnotgas is offline   Reply With Quote
Old April 18th, 2018, 13:38   #51
16vjohn
At about 38k, my Jetta started rattling near the pedals. All the usual solutions have come up empty. Getting used to it... kinda reminds me of my Mk3 now that I think about it.
15 Jetta TDI 37k // 11 Ford Fusion
Retired: 13 Passat, Buyback // 01 Jetta TDI 177k // 98 Jetta TDI 291k // 00 Jetta TDI 240k // 91 300D 2.5T // 90 Jetta TD
16vjohn is offline   Reply With Quote
2006 Jetta - New Clutch - Rattles? dtreid VW MKV-A5 Golf/Jettas 5 January 20th, 2012 07:08
2010 Jetta Dash Rattles ekimsepol TDI 101 5 June 27th, 2011 16:18
The 1985- 1992+ (+CAN) 1.6/1.9 IDI hydro-head FAQ, and not so FAQ thread valvecrusher Other VW Group TD(I)s 14 August 3rd, 2010 11:48
04 jetta pd ... rattles buzzes lee007 VW MKIV-A4 TDIs (VE and PD) 3 March 20th, 2004 00:39
Jetta sqeaks and rattles rammell TDI 101 13 June 2nd, 2001 18:59
Page generated in 0.13750 seconds with 13 queries
[Output: 82.04 Kb. compressed to 72.38 Kb. by saving 9.66 Kb. (11.78%)]
