Ok, I think I'm going to pick these up from egauges.com
dual column pod (for my Faria fuel level and fuel temp gauges for the WVO conversion)
3 gauge DIN panel
VDO Vision Pyrometer kit to 1650 (should come with everything, right?)
VDO Vision Boost gauge (0-30 PSI)
10 ft nylon boost sender kit
VDO Vision Oil Temperature (300F)
323-423 10-180 300F M10x1 temperature sender
4 blue 4 LED 192 bulbs
I only need to supply the wire and electrical connectors, right?
The boost sender kit
CON 011 should have everything I need to tap into my intake and measure the boost, right?
What's with the VDO pyrometer and its light? What type of light bulb do I get for it so it'll match the rest of my gauges?
The oil temp sender. Will this fit the plug by my oil filter? Do I need anything else for this?
Thanks. I'd buy from 42draftdesigns but I want the column pod and 4 LED lights.
Not sure about doing it myself as I don't have instructions.
