Jicafold
So I have a 2012 Audi A3 TDI. It has a difficult time starting when the engine is warm, as if you drove it for a while, stopped and went shopping for 15 min, came back, and tried to start it again. It takes anywhere from 3 to 10 tries to start it. I have no CEL. A friend with VCDS ran a scan and said it is the engine speed sensor. The scan message is posted below. So where is the engine speed sensor located? As an intermittent signal I understand it may only need cleaning, which I was going to try first. But if I wanted to buy one Google only wants to sell me a crankshaft or camshaft position sensor. So 2 questions:
Where is this part located on the motor?
Where can I buy one if I need to?
Thank you.
Address 01: Engine (CBE) Labels: 03L-906-022-CBE.clb Part No SW: 03L 906 019 EJ HW: 03L 906 019 EJ Component: R4 2,0L EDC G000AG 8176 Revision: 12H14--- Serial number: AUX7Z0K4FNV00D Coding: 0050078 Shop #: WSC 84224 299 600232 VCID: 77D30FE706D10FF9D8-80221 Fault Found:000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28) P0016 - 000 - Incorrect Correlation - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 2 Fault Frequency: 75 Reset counter: 255 Mileage: 156269 km Time Indication:
Thank you.
