Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Audi SUVs (Q7 & Q5) and other V6 TDIs
Audi SUVs (Q7 & Q5) and other V6 TDIs Discussions area for Audi Q7 and Q5 TDI (2009+ in Canada & the US) as well as others with the V6 TDI such as the A6, A7 and A8 sedans.
Old October 18th, 2019, 12:24   #1
av8r
Fuel Economy: 101,500 Miles Avg 38.5 MPG
Default 2014 Q5 TDI Transmission Fluid/Filter
Fellow compression addicts,
After a TON of research (you have to search hard for P/N's and compatibility--(BTW I think that's on purpose)) I figured I'd pass on some info/prices to change the fluid/filter in the 8 speed Triptronic transmission (0BK).
Found the best deal on GREEN ATF on EBAY. I got febi Bilstein Nr 39095 for just just under $19 a liter (9 required).
Found the best deal for the filter/gasket/hardware kit 0BK-398-009-A-M103 at https://www.pelicanparts.com/ (I'm not affiliated with them at all). You have your choice of three different brands. Anyway, great prices and free shipping from Los Angeles, Ca. I'm in Las Vegas so it was delivered the next day.
Nothing on these German machines are cheap. I'm guessing if the Dealer did this it'd be $$$$. Hope this helps someone out there.
2014 Audi Q5 TDI
2010 Jetta TDI - Settled/Sold to VWGoA Sept 2018
2003 F350 PS Diesel 6.0
av8r is offline   Reply With Quote
Old October 21st, 2019, 07:33   #2
dunerking
dunerking's Avatar
TDI(s): 04 Jetta TDI
Thanks,I usually do most of my maintenance but with these transmissions it my understanding that the fluid needs to go in at a certain temp for a accurate fill as there isn't a trans dipstick.
05 Dodge 3500 CTD,2.5 Carli suspension
13 Porsche Cayenne diesel
12 JSW OEM fog lights(sold back to VW)
04 Jetta-5 speed
dunerking is offline   Reply With Quote
Old November 9th, 2019, 07:44   #3
A1sailor
Av8R, did you get the fluid and filter change done? How many litres did the 8 speed need?
I read others used 6 to 7 litres.
Did you need 9 litres?
A1sailor is offline   Reply With Quote
Old November 11th, 2019, 02:18   #4
commedeschatons
4-5L with a pan drop. You will not be able to get 9L out when doing a filter change, the kits that come with 9 will leave you
Ravenol 8HP is what i used, which is specifically approved for 8hp trans.
I would recommend others to use this or the ZF lifeguard fluid.
I tried Redline D6 ATF and it made the transmission act a little weird.
commedeschatons is offline   Reply With Quote
Old November 11th, 2019, 15:13   #5
A1sailor
Thanks for info,
I'm going with the Ravenol 75W- 140 GL5 for Q5 transfer case, apparently VW ok at cost $25/ litre, it has a friction modifier.
Lifeguard 8 and the Melye transmission filter gasket kit for transmission.
What should I do with my 2014 Audi Q5 TDI? sangshin87 Dieselgate - VW Group Emission Scandal 3 March 8th, 2017 07:31
Thinking about a 2014 Q5 TDI TDI_Brad Audi SUVs (Q7 & Q5) and other V6 TDIs 13 February 17th, 2016 05:02
2014 Q5 TDI tuning KatchMeRacing Audi SUVs (Q7 & Q5) and other V6 TDIs 4 June 12th, 2015 18:07
Tuning the 2014 Q5 TDI GTT Audi SUVs (Q7 & Q5) and other V6 TDIs 0 October 28th, 2014 21:01
Car louder and slower after newTimingBelt, Fuel Filter, Transmission Fluid and Filter TanManIsTan VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 18 June 15th, 2013 15:19
Page generated in 0.11697 seconds with 12 queries
[Output: 69.41 Kb. compressed to 61.42 Kb. by saving 8.00 Kb. (11.52%)]
