andydg
It sounds like a stupid question, but let me explain.
Recently, after doing a cross rotation on my tires (due to a slight pull, after alignment) my Sportwagon began to vibrate a bit at speeds between 75-80mph.
The tires were checked and found to be out of balance.
Ride went back to normal for about 250 miles, when it began to vibrate again.
Another balance, normal, then again at around 200-250 miles same issue.
This repeated several times until tires were replaced for new set, and the issue still rears its ugly head.
Vehicle has 102,000 miles, wheel bearings feel tight (also no noise), suspension is tight (Koni yellows, H&R sports)[no play in upper strut bearings], tires are being road force balanced each time, tie rod ends feel tight (no play in steering).
When they go out of spec, they are 3/4-1 ounce off.
I thought that perhaps the tires are slipping on the wheel (Neuspeed RSe05), but the older set were not removed and had close to 15k miles on them.
Tires are Michelin btw. Older set Premiers, new set A/S 3's.
Vehicle tracks straight and true. Also @ 100mph it is smooth again. (though I'm sure the feds would frown upon my driving at that speed all the time)
