ryanp
- Joined
- Jun 22, 2008
- Location
- Barnsley, South Yorkshire, UK
- TDI
- Arosa CR - 550hp - 9.7 @ 150mph 1/4 Mile, Citigo 4x4 CR TDi - 340hp, Caddy 2.0 CR 4x4 TDI - 300+hp, Golf Mk2 Van 1.9 TDI - was 290hp, Mk5 Ibiza 2.0 FR TDi - 270hp, BMW 135d - 360hp, BMW 330d - 335hp, BMW 335d - 380hp + a few more ........
Ryan P's 02M 6 Speed Tranny Conversions
Hi,
I have sold over 100 of these 6 Speed conversions now, so there are a lot of very happy people cruising on the freeway in 6th!
These come with all the items you see in the picture. It is everything you need to upgrade from a 5 Speed Manual to the 6 Speed.
A few more parts are needed to swap out an auto (see below).
5 Speed Manual to 6 Speed Parts list:
02M 6 Speed Gearbox
2 x Drive Shafts
Used Dual Mass Flywheel and Complete Clutch Kit
Gearbox Mount
Dog Bone Mount
Starter Motor
Dust Tins from the Engine
Shifter Mount and End Links
All bolts required (New where needed)
If you need the Linkage Cables, please let me know (mainly needed for 99-00 5 Speed and All Auto cars, as the later 5 speed one will work with the 6 Speed)
The Shifter Knob's and Boots are hard to get in usable condition, I can get them but the kit will be an extra £30.
The price for the complete conversion is £1250, price increase due to the difficulty in sourcing these over here now. Please bear in mind that £300 of the cost is for shipping alone! I have now started to include ALL the bolts required for the conversion, including new bolts where the original are single use only.
I HAVE JUST RECEIVED A DELIVERY OF SOME BRAND NEW PD150 VW/SACHS DUAL MASS FLYWHEEL AND CLUTCH KITS WITH GENUINE VW RELEASE BEARINGS, THE COMPLETE KIT WILL BE £1650 INC SHIPPING WITH THESE.
AUTO TO MANUAL CUSTOMERS
I can supply all the extra parts you require brand new, including the Clutch Pedal Assembly, for £320
Here are the different Subcode ratios to compare:
I can get the ERF easily, DRW's are not too bad but in demand. FMH's are not so common and I have only ever seen a few EFFs!
A new Clutch fluid line is not needed for a 5 to 6 Speed conversion as the stock one works with a little tweaking. If you really want one it's the same on the Gasser 6 speeds you guys actually got, the VW Part number is: 1J1 721 465 AJ. I can get them for £60.
Also bear in mind that if you are converting from a 5 Speed, you will have everything available to sell your old parts as a complete conversion for the Auto guys. I have seen the 5 Speed conversions fetch up to $1000 (Even more in Canada!)
PLEASE TAKE A LOOK AT THIS GUIDE BY BOERTJE -
http://pics.tdiclub.com/data/517/Boertje_Auto_to_6_spd_manual_swap_and_wiring_instructions.pdf
THANKS JACK!!!!!!!!!
If you want any other Euro Parts please drop me a PM. Anything ordered with a Gearbox will have a reduced price due to lower shipping costs, so please PM if you want to purchase a few different items.
All prices quoted are in £ / GBP / British Pound and INCLUDE SHIPPING to the USA and Canada. For estimated conversion rates, please check http://www.xe.com/. PayPal does give the exact exchange rate when you go to send the payment.
Everything is sent via DHL Express (usually 48hrs) which is tracked all the way with a signature at the end. I have my own 'Goods in Transit' insurance policy so you have nothing to worry about should anything go wrong.
Lead times are 1 – 2 weeks (unless I have what you want in stock, I try and keep a few full conversions in at any one time). Delivery times are normally 24-48hrs across the US, Canada are 48hrs but can be a little longer due to Customs. I've had many of these Gearbox conversions arrive in 24h or less!!
I can take payment by either Wire Transfer or PayPal (5% Extra to cover fees)
Thanks for looking!
Ryan
Hi,
02M 6 Speed Gearbox
2 x Drive Shafts
Gearbox Mount
Dog Bone Mount
Starter Motor
Thanks for looking!
Ryan
