guillaumeber
Hello!
My brake pedal feels pretty soft, I've bled the 4 wheels and clutch in the good sequence 3 times, still soft.
The car brakes but the pedal is pretty low when the brakes finally grabs (below the level of the gas pedal)
All I did is change the 2 rear calipers...
I've read I should try to bleed the brake booster but there is no bleeder, what is the correct procedure?
Should I also try to bleed the ABS module with VCDS even though I don't see how air could have gotten to this module...
thanks a lot
g.b.
thanks a lot
g.b.
