afmeyer9
I need to replace my battery on my 2002 Jetta TDI. This will be the third battery which I guess is pretty normal. Is there any battery that really stands out as being much better than the rest?
+1, had the oem in my mk4 for 9 strong years with a little maitenance and trickle charge a couple of times a yearThis is the only time I would EVER go to the dealer... The VW Batt is a good one. 4, 5, 6, 7, 8, or even 9 years on a stock Batt those odds are ones I would go the the "track
" with, so to speak.
To quote the late great Carl Sagan: there are "billions and billions" of threads on this... and they all end with either a huge pissing match over CCA vs Ah ratings, or "get the OEM and be done with it"... or both.Plenty of battery threads covering this already.
I agree with the above. After 5 years my batteries get changed out. I've heard good stuff about the VW OEM ones.May want to think twice about pushing a battery's life span. Preventative replacement may save an altenator.
A family member just recently had an expensive lesson. Battery was probably 5 or more years old. He left his lights on. Got a jump start and everything was good for a couple days, then he went to start it and nothing. Replaced the battery and it made it another 100 miles and it died. Tow, dealer altenator and labor later he learned that a stressed battery can kill an altenator in no time.
Moral of the story... Don't try to set records on the number of winters you can get by before you replace it. As soon as you start noticing sluggish starts... it's time. Otherwise your altenator is going to burn itself out trying to fully charge a battery that just won't hold it.
I can't tell you which one is best, but I have been very happy with the ones I have gotten from Sam's club. I have replaced the battery twice (now I am on the third battery) I bought a good one and the warranty paid for two replacements. BTW, I did not even have to ask for the warranty deal. I had forgotten it even had a warranty but they called me over and told me it was under warranty without me even asking. So I have paid for only one battery since 2002.I need to replace my battery on my 2002 Jetta TDI. This will be the third battery which I guess is pretty normal. Is there any battery that really stands out as being much better than the rest?
Your tune is on a flashROM, if I'm not mistaken. If so, then it is impervious to loss of voltage.does going to the dealer to replace your battery "erase or mess with your tune"
I am at the dealer and they said they were going to messing with settings" and such i was gonna have them replace it but after they said they were going to mess with my comp i had second thoughts. btw my battery is OE and has gone 180k miles ish and lasted almost 9 years
I dont' think anyone said you should have the dealer change your battery... just buy it there and put it in yourself. That should solve all your problems.does going to the dealer to replace your battery "erase or mess with your tune"
I really think you are in the minority on this one. I've read a lot of battery threads around here, and many of us got 8 or so years out of our original OEM battery.the factory battery was toast after the first winter terrible battery
How long did your OE battery last? 6-8 years?My OEM battery was very good. I got a replacement from Sam's Club and over the years I have had three replacements, at no charge.
I don't recall. That was a while ago.How long did your OE battery last? 6-8 years?
