Hi everyone. Maybe my problem is already solved and explained somewhere in forum, but I was unable to find.
I'm driving 2002. 1.9 TDI 74kW. Last year I replaced clutch completely (DMF, clutch disk, pressure plate, release bearing).
Even before changing, clutch engage point was in lower region but not extreme.
After changing kit, clutch pedal became soft and engage point is just near from floor, and there is almost ne resistance in upper half pedal movement. I changed slave cylinder with new one but there is no change. After that I changed master cylinderwith used one (used about 2 year but sit on shelf about 10) but there is no change again (the new one at the moment was unable to find).
I changed oil fluid and drained it several times and situation remained same.
What can be the problem? Is the master cylinder or something else?
What can it be.
What can it be.
