HoosierTDI
I talked to CoolAirVW and he told me his rebuilt valve bodies for the 01M like I have in my 02 Jetta TDI fix the problem my scan codes (and the VCDS scan codes a VCDS owner got for me) indicate a great majority of the time. So, I take my car to a local garage and tell the guy I want him to take a look at the trans for wear.
I thought he would drop the pan, look for a lot of metal shavings and such and come out and tell me if there were a lot of metal particles indicating a lot of wear in the gears and such or tell me not a lot in there - then I would know if the valve body replacement would work, or if the trans had gotten beyond the point where valve body replacement was going to fix it. Figured if he was a good mechanic he would even bring the pan in and show me.
So, he drives it in, hooks it up to the scanner, then comes out and tells me that the code he got indicates a bad trans and torque converter and I should replace both - for a fee, of course. Hehe
I tell him I have consulted people who specialize in this type of car and the transmission in it, and explain to him the best way to check for what I want to know is to drop the pan, look at the magnet in the pan and tell/show me if there are a lot of metal particles in the pan.
With a straight face, and without even breaking eye contact, he tells me his scanner indicated that the 'wear sensors' in the trans were showing that the trans was 95% worn out He said it must be replaced!
How do these guys even stay in business? But I wouldn't play poker against the guy, 1 He would probably try to deal from the bottom of the deck, and 2 he had one HECK of a poker face - when he told me that his expression didn't even flicker. lol
I didn't tell him I have a high end scanner, probably as good or better than the one he was using in his 'shop' (not as good as VCDS I know, but I had someone scan it with VCDS as well).
I also didn't tell him that while I don't work on cars much, my dad was an ASE Master Mechanic who had people bring cars to him from 100's of miles away in our state and other states. I do know a little about them, my brother knows much more. By the time I started kindergarten I could do my ABC's and read (my mom) and I could tell you a 5/8ths socket was bigger than a 1/2 inch and what a tenth, hundredth or a thousandth was (my dad).
I'll drop the pan and check for myself. Just thought you all might get a kick out of that one. lol
