Old January 9th, 2018, 08:41   #1
steve-4464
Default Flywheel 2013 Sportwagen 6 spd manual
Looking for identifier on which flywheels, single or dual, that will fit on my 2013 Jetta Sportwagen manual.
Parts guys ask for VIN and that doesn't seem to help in search. Don't need rugged fix as I plan on selling it back eventually.
thanks!
steve-4464 is offline   Reply With Quote
Old January 9th, 2018, 15:12   #2
ihatespeed
Fuel Economy: 40mpg city 46 avg, 50 hwy 33 trailer
Its going to be a dual mass flywheel unless you already have a single mass conversion (IE not stock) you need to identify if you have a sachs or luk, apparently they are not compatible (mix and match) sounds like the only way to know is to open it up and look.
However you should be able to get a complete clutch kit with matched flywheel for any CJAA / 02q combo and be fine. Id check out id parts, ive had really good luck with them, and they are right here in Mass.
Now if you want to save some bucks you can probably get a complete valeo single mass kit for less than the price of a flywheel, you're not just going to replace a flywheel anyhow, the friction disk and pressure plate are a no brainer considering the amount of work to get into the thing. figure about 800 for a dual mass clutch kit and flywheel, and about 650 for a single mass conversion.
Andrew's 3rd generation (2Micron.com) return fuel filter, and Pure Flow HPFP modification, timing belt guard and the full Malone flashzilla / Buzzken stage2.0 eco treatment (bosal hitch and heavy springs for towing)
ihatespeed is offline   Reply With Quote
Old January 9th, 2018, 15:44   #3
turbobrick240
turbobrick240's Avatar
I replaced the Sachs dmf, clutch disc, pressure plate, and throw out bearing/slave cyl. with a Luk dmf clutch kit on my car. You can find the Luk kit and DMF for about $520 if you shop around a bit.
Old January 10th, 2018, 07:52   #4
steve-4464
Thanks for the input!
2012 Sportwagen TDI 6-spd manual, 16k mi - Detroit andrew-detroit TDI Cars for Sale/Wanted 0 February 26th, 2014 07:44
2013 TDI Sportwagen w/6sp manual for sale MichaelM TDI Cars for Sale/Wanted 0 December 29th, 2013 12:24
2013 Jetta TDI with Premium 6 SPD Manual Rocketman1321 TDI Cars for Sale/Wanted 0 October 19th, 2013 16:53
09 SportWagen, 6 spd manual, sunroof! dakarm34 TDI Cars for Sale/Wanted 3 December 5th, 2010 19:13
For sale: MkIV TDI 5 spd manual transmission, flywheel, and drive axels mihaj Private TDI Items for Sale/Wanted 17 July 20th, 2010 14:31
Page generated in 0.12619 seconds with 11 queries
[Output: 63.15 Kb. compressed to 56.48 Kb. by saving 6.67 Kb. (10.55%)]
