Imortl
Hey everyone, new member to the forums but long time viewer. Most problems I've been able to fix by looking at other threads. So my problem is with my brothers car a 2013 passat tdi auto. He took the car to a malone dealer to get the full delete( egr, dpf, def, cats) with malone stage 2. The car got worse fuel economy than stock and rolled alot of deep black smoke. The malone dealer couldn't figure out what data logs to send malone to fix the problem and was told to just deal with malone to fix the problem. My brother then had to buy vcds and flashzilla to get the tune fixed with malone. He then tried to data log and send malone the correct parameters but doesent know which exact ones to send malone. My brother was told to send fuel rail pressure, injection quantity, rpm, boost requested by the ecu, actual boost, actuator position with voltage, but when he searches for those in the ross-tech vcds software either nothing comes up or the the paramaters arent titled that and there are several related ones to choose from. He is drawing the last straw here with close to 2,000$ in trying to get it deleted and running right to see mpg gains. So i am looking for someone who has a 2013 passat tdi that has had success in their delete and can help me provide malone with the parameters to get the tune done correctly.
I am awaiting the success of my brothers car. And am anxious to get my 2015 jetta tdi deleted but am being drawn away from malone seeing my brothers problems. Thanks for any help!
