Old December 28th, 2017, 20:05   #1
pkhoury
That guy with the goats
pkhoury's Avatar
Fuel Economy: CR - 36-41, PD - 39-48 (26-32 while towing)
Default Sportwagen panoramic sunroof curtain busted
Just curious if anyone's had to get their panoramic sunroof curtain replaced. Apparently, the adhesive on my curtain decided to come loose from the passenger side (and partially from the driver's side), so the spring got jammed in the rear. So then, when the mechanism felt that extra tension, it reversed and made the problem worse.
I'm just wondering if it'd be a better idea to get 5% tint (aka limo tint) and remove the fabric.
2010 Jetta Sportwagen - Malone DSG tune, Malone Stage 3.5, CR170, buzzken 3" straight pipe(resonator deleted), PolarFIS, Panzer plate, front and rear fogs, Bosal towhitch, Bilstein B8/Neuspeed 28mm swaybar, 2micron CP3 upgrade kit
2004 Golf GLS 5MT -
Malone Stage 4, VNT17, DC Stage 2 clutch, buzzken 2.5" straight pipe, MFA cluster swap, dieselgeek Panzer plate and short shifter, Bosal towbar, Tekonsha P3 brake controller, Hopkins short-proof trailer light converter, darkside SMIC, intake manifold, and tip pipe, PD150 airbox
2005 Jetta Wagon GLS (mom's car) - Malone Stage 4, VNT17, MFA cluster swap, Panzer Plate, buzzken 2.5" straight pipe, darkside SMIC
2015 Golf Sportwagen TDI (mom's car) - stock for now...
Other diesels:
Ford 5900 tractor
Ford 3400 Industrial tractor
2016 Mahindra XTV (1L Kohler diesel)
pkhoury is offline   Reply With Quote
Old December 28th, 2017, 21:17   #2
JSWTDI09
JSWTDI09's Avatar
It would certainly be easier to tint the sunroof and probably cheaper as well.
There is also a company called "Heat Shield" that makes a insulated heat shield for the pano roof just like the ones you can put in your windshield. It is not as pretty as the factory shade, but it is far more effective. If you are interested in going this way, shoot me a PM. I have one from my JSW but I haven't started a for sale thread yet.
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old December 31st, 2017, 21:20   #3
SkiBumJH
I did exactly that. Fabric came off on both sides . Things got worse... cut the fabric out and tinted with a metallic base for extra heat resistance/reflection. worked perfectly. Have heard of car interior repair guys who can re-glue it fairly easily though. Replacing the shield and motor is involved but doable too.
SkiBumJH is offline   Reply With Quote
Old January 7th, 2018, 00:42   #4
ricks
ricks's Avatar
Fuel Economy: 38ish mixed, 49 highway
I recently posted where did all the old technical threads go? Here is another one which was covered as well as the one on trunk latches. For people new to this site, they would never know how much material is out there, but hidden..why not unhide the technical stuff to be more user friendly?
Rick S, '10 JSW TDi, '71 914-6 3.0
ricks is offline   Reply With Quote
2009 Jetta Sportwagen panoramic sunroof LEAK SFL_TDI TDI 101 89 November 18th, 2015 18:26
Panoramic Sunroof. Seaflea VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 51 October 6th, 2015 07:54
2011 TDI Jetta SportWagen With NAV & Panoramic SunRoof MoreGuns TDI Cars for Sale/Wanted 1 June 12th, 2014 09:10
Any problems with the panoramic sunroof? vapour VW Beetle 2012+ 5 August 21st, 2013 12:58
Panoramic sunroof - to have or not ruschbr TDI 101 17 December 16th, 2012 20:34
Page generated in 0.13872 seconds with 11 queries
[Output: 65.92 Kb. compressed to 59.11 Kb. by saving 6.81 Kb. (10.33%)]
