Old October 17th, 2015, 16:28   #16
vanbcguy
vanbcguy's Avatar
Originally Posted by KCCats View Post
Sorry for digging this up once again, but why can't I just flush with water and use standard anti?
The VW stuff will last a lot longer.
My build thread: http://www.vwdiesel.net/forum/index.php?topic=32967.0
vanbcguy is offline   Reply With Quote
Old October 18th, 2015, 08:27   #17
KCCats
I don't think at this point I care!
KCCats is offline   Reply With Quote
Old January 6th, 2018, 10:49   #18
Manu
Manu's Avatar
Had to top up the coolant this morning as the warning light came on, it was a bit below MIN.
G13 Cool-Aid
by MANU01, on Flickr
...and the owner's manual for my 2010:
G12 Plus or Plus Plus
https://www.wolflubes.com/EN_EU/Blog...d-coolant.aspx
.:BG 2010 Golf Wagon TDI 6MT Highline:.
.:SB 2017 Golf TSI 5MT Highline:.
Manu is offline   Reply With Quote
Old January 6th, 2018, 11:22   #19
I've never found the descriptions of coolant by color useful. They're all too similar to me, with the exception of G11, which is clearly blue/purple.
If you take G11 out of the equation (there are probably about 5 cars left with that in it, anyway), all VW coolants are compatible: G12 through G13. However, I personally would not mix G12 into a car that was manufactured with G13, there's no reason to. But I would top up a car with G12 in it with G13.
Old January 6th, 2018, 11:59   #20
turbobrick240
turbobrick240's Avatar
That's interesting- why would you add g13 to g12, but not vice versa? G12++ and G13 are essentially the same- except G13 contains glycerine. I topped my '11 up with g12++ after the timing belt service. Not sure what was in there from the factory, though the chart above seems to indicate it was g13. The color looked closer to g12++, but I agree the difference in color is pretty subtle.
Old January 6th, 2018, 15:28   #21
If you can top up with the same fluid as the original fill, why not? There's no harm in using G12, +, or ++, but I'd be more comfortable with not mixing. Maybe after the car has a few hundred thousand miles on it I'll feel different. I'm also using the last of my OE VW washer fluid concentrate in that car. Love that smell.
Old January 6th, 2018, 16:22   #22
turbobrick240
The problem I had was determining what the OE coolant actually was in my '11. I initially thought g12++, the expansion bottle is marked g12, and everything I've seen since indicates it should have been g13. Since glycerine in the coolant was new to me(and maybe a little suspect), I opted for g12++.
Old January 6th, 2018, 20:14   #23
turbobrick240
Here's a link to another coolant compatibility table that made more sense to me:
http://www.underhoodservice.com/volk...ants-tech-tip/
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
G13 Coolant better for environment? But any good in our TDIs? s.pavel6 Fuels & Lubricants 9 January 26th, 2013 09:47
G13 Coolant Pink/ 507 synthetic maniago VW Passat Family (NMS and B7) TDIs (2012+) 26 July 18th, 2012 08:55
G12 coolant dunl Central Canada 6 October 29th, 2009 05:35
Where to get G12 coolant? Str9012 Fuels & Lubricants 7 June 19th, 2007 20:32
Need G12 Coolant -- Where can I get it? Tussey VW MKIV-A4 TDIs (VE and PD) 11 November 25th, 2003 23:46
Page generated in 0.15536 seconds with 11 queries
[Output: 89.96 Kb. compressed to 77.54 Kb. by saving 12.42 Kb. (13.81%)]
