Old January 4th, 2018, 14:36   #1
jennogle
jennogle's Avatar
Fuel Economy: 48/36
Unhappy EGR Cooler VW warranty
I took my car in for the Recall Fix, etc. and all was done except the dealer claimed that the EGR Cooler is leaking coolant and needs to be replaced. They say this is due to a "bend" near the lower coolant pipe leading into it. They think the bend was due to something my regular mechanic did ???, so they won't cover replacing the EGR Cooler under the extended warranty. To my knowledge, my regular mechanic has not worked on this part of my car. The dealer has quoted me $1400 for the repair. What should I do?
jennogle is offline   Reply With Quote
Old January 4th, 2018, 14:46   #2
calimustang
Go to other VW. I dont think they are honest.
2011 JSW TDI retired and buyback, gone to heaven. almost 300k miles.
2015 Passat TDI with 22k miles on 5/6/2018, completely stock. Black exterior and black interior, 5% tints all around. Now 32k on 9/18/2018.
2014 JSW TDI bought used on 8/26/2018 with 27k miles, white with cornsilk interior. 5% tints, all stock.
calimustang is offline   Reply With Quote
Old January 4th, 2018, 15:03   #3
jennogle
jennogle's Avatar
Fuel Economy: 48/36
Wish there were another dealer near me, but there isn't.
Old January 4th, 2018, 15:12   #4
calimustang
Then go to your local mechanic who has worked on your car before VW and see what he sees then go from there.
Old January 4th, 2018, 16:27   #5
jennogle
jennogle's Avatar
Fuel Economy: 48/36
My local mechanic quoted me $800 for the EGR cooler. He can't do a warranty repair, of course. And he has no idea how the coolant pipe got bent. Dealer says no way it spontaneously bent. ??? The dealer offered to do the repair if I pay them $1400, and send in for VW to review and 'possibly reimburse'. Should I do that or just have my local guy do it?
Old January 4th, 2018, 18:50   #6
calimustang
Thats like an Russian roulette.... they may NOT reimburse you if they found it to be tampered with. You would be out of $1400. If it was me, I would go DPD/EGR delete and be done with it. Also CP3 pump swap. You will never look back. You will enjoy the car a lot more. Do you have emission testing and inspection required in your state? In FL we dont so thats why I went this route as I mentioned recently.
Old January 5th, 2018, 05:54   #7
740GLE
Do the $800 repair, then the emission fix, get paid, then delete/tune at the first sign of emissions issues.
Old January 5th, 2018, 07:52   #8
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
At the end of the day, if the pipe leading into the cooler is bent and leaking, then that is not the fault of VW.
Have you seen the bent pipe directly? is it bent? if so, whoever bent it should be the one held responsible.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old January 5th, 2018, 16:15   #9
jennogle
jennogle's Avatar
Fuel Economy: 48/36
No, I haven't seen it. I suspect the people that told me about it (the stealership) are the ones who bent it, though I have no proof...
Old January 5th, 2018, 16:17   #10
jennogle
jennogle's Avatar
Fuel Economy: 48/36
Already had the big fix done back in November and got my $. I don't know what y'all mean by "delete" ... Are you saying you just removed the EGR system entirely? I live in TN so there are no state inspections of any kind.
Old January 6th, 2018, 10:27   #11
piotrsko
piotrsko's Avatar
Fuel Economy: 46 city/56 hwy so far wonder what the Golf gets
Fix warranty states if it sets a check light the problem is warrantied at no cost.
They cant fix it if it had a check light on when they did the fix.
Sounds like you nee to open a complaint at VW
piotrsko is offline   Reply With Quote
Old January 6th, 2018, 21:29   #12
jennogle
jennogle's Avatar
Fuel Economy: 48/36
It didn't have a check light on when they did the egr fix - or since. They noticed the leaking coolant when they were doing the fix and opted not to replace the egr cooler because of the bent pipe. I have no way to prove the pipe wasn't bent prior to their performing the fix.
WTB Flex Metal hose for the EGR cooler & all 3 EGR Cooler rubber hoses tothemax Private TDI Items for Sale/Wanted 5 July 29th, 2014 08:43
EGR Cooler for VW? diezealous TDI 101 3 April 15th, 2014 10:40
Emmissions Warranty and EGR cooler - '06 TDI CSL06TDI VW MKV-A5 Golf/Jettas 1 June 10th, 2009 20:13
FYI VW EGR Cooler Re-Call atifvw Ontario 4 September 6th, 2006 17:56
EGR Cooler Warranty Invoices spicy_red VW MKIV-A4 TDIs (VE and PD) 4 January 9th, 2006 14:16
Page generated in 0.14988 seconds with 13 queries
[Output: 109.58 Kb. compressed to 91.92 Kb. by saving 17.67 Kb. (16.12%)]
