Old December 9th, 2016, 09:55   #5326
TDI57
Fuel Economy: 45.7
Originally Posted by TDI57 View Post
My fix, drain it away.
IMG][/IMG]
Update:
Temps have dropped in Columbus OH.
Last night I raised one side of my car to switch to winter tires and heard what sounded like a water leak. Thought is was odd until I thought of my drain hose. Sure enough I checked and water ran out onto my metal drip pan on the garage floor. It was a substantial enough volume to hear dripping into the pan, at least several tablespoons worth.
So glad I have that simple tiny hole. Works as I expected. It is a really good feeling to see that water come out rather than stay in the system, potentially causing hydro-lock.
For the few of us keeping our TDI's, I highly recommend this simple trick.
Like winter or not, here it comes!
TDI57 is offline   Reply With Quote
Old December 9th, 2016, 12:52   #5327
STRANGETDI
Did you order the fuel nipple from here?
http://www.sullivanproducts.com/Sull...et_Catalog.pdf
Page 8 of the PDF
Chris
CURRENT: 2012 GOLF w/ TECH, 4DR, 6SP MANUAL, 116K miles
OLD: 1999.5 Golf GL TDI,Up'd,.216s,17 OZ Rims,Eibach Pro-Kit&Dampers,TT SS 2.5" Exst. 222,000 - Sold to Rossman83
STRANGETDI is offline   Reply With Quote
Old December 10th, 2016, 04:39   #5328
TDI57
Fuel Economy: 45.7
Page 8 of the PDF
Yes I did. Great company, I described what I was looking for and they actually shipped to me for no charge!
Old December 20th, 2016, 16:06   #5329
milleraw
milleraw's Avatar
AHHHHHHHH! Please tell me I am Hydrolocked.....95,000 miles on 2010 TDI sport wager and doing buyback next week.
How do I get the water out of the cylinders. Pull glow plugs?
Sent from my iPad using Tapatalk
milleraw
'10 Jetta Sportwagon TDI Silver, Portos, Roof
'10 Jetta Sportwagon TDI White
milleraw is offline   Reply With Quote
Old December 21st, 2016, 05:27   #5330
milleraw
milleraw's Avatar
Ok...it appears that my engine is Hydrolocked. T-belt checked. Engine can not be turned by hand. This all happened during starting on a warming day (50F) after a evening in the 20s.
How do I unlock? Pull the glow plugs?
I have tried rotating the engine from the crankshaft. It would not move either direction.
milleraw
Old December 21st, 2016, 05:46   #5331
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
milleraw,
Check out this video. Yes, he pulls the glow plugs. Also, he drains the intercooler. https://www.youtube.com/watch?v=9Teyq-EdC_s
Good luck, please let us know how everything works out.
2010 4D CWhite Golf TDI, 6 sp manual, Fluidampr, Bixenons, Rear Airbags, RNS-510, Dynaudio, DieselGeek SS & P2015 bracket, Force Fed Eng. Shifter Bushings. XB,UB, & RB UNIbraces; TyrolSport Brake Caliper Bushing, 2Micron Contain/PureFlow kits & timing belt cover, PolarFis MFD module, Euro light switch, R Red LED Tail Lights,Under Seat Drawers, Full color MFD cluster.
bobt2382 is offline   Reply With Quote
Old December 23rd, 2016, 13:54   #5332
milleraw
milleraw's Avatar
Default Hard Start / No Start - Is your intercooler frozen? Check Here!
Originally Posted by bobt2382 View Post
....please let us know how everything works out.
Wow! That was crazy scary...I went from engine is F'd to it runs fine in 5 minutes. Was warm enough today to remove the plugs and crank the engine over. Also pulled the bottom cover and drained the lowest IC hose. It now has a 1/8" hole in it as well. This will not happen again. Car needs to make it to February for buyback.
See link for pictures:
https://goo.gl/photos/fc6G57QieKNhnsae9
milleraw
Old December 23rd, 2016, 15:10   #5333
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
Yeah, nice. Glad to hear that its running! I should really drill a hole in my IC hose.
Old December 24th, 2016, 05:00   #5334
TDI57
Fuel Economy: 45.7
When I see posts like this is reminds me how glad I am that I have my weep hole in mine, I still see water on the ground from time to time. Better on the ground than in my plumbing or cylinders!
Old January 10th, 2017, 13:40   #5335
GTSLOW
GTSLOW's Avatar
So mine went down today. Ran for a brief second and died. I've already drained the 2+ cups of water from the IC hose. Now I can't get these damn plastic glow plug bungs off....
'15 Golf Sportwagen S M6
'04 Golf M5 - Koni STR.T's,H&R OE Sports, & Buzzken 2.5" Exhaust
'12 Jetta M6 - Sold back 6/29/17
'15 Passat SE M6 - Sold back 12/22/16
GTSLOW is offline   Reply With Quote
Old January 10th, 2017, 14:08   #5336
kjclow
My wife's car ran rough and died on her before Christmas. She was sitting in fairly heavy traffic but no one hit her. Thank goodness. She was able to restart after a few minutes and no issues since then. This is the first stall on either of our cars. Her's goes back to VW the end of Feb, so hope no more issues.
Old December 28th, 2017, 22:28   #5337
rhaus
Not sure if it has been mentioned yet, but the work outlined on the technical bulletin is covered under the extended warranty that comes with the emissions fix (or at least it is on my 2012 Golf w/ manual transmission). Worth looking into for those of you who kept your cars. With the current cold snap, right now is a good time to drive the car 30-40 minutes before dropping it off at the dealership. They will pull the IC lines off, look for water/ice and will most definitely find it....
2012 Golf TDi
rhaus is offline   Reply With Quote
Old December 31st, 2017, 17:43   #5338
SAR_TDI
Default Hard start and VW upgrade 11/2017
My 2011 manual Jetta Sportswagen had 2 fluid locks from the intercooler that I survived with luck and ignorance. Later, I cut the intercooler hose and inserted a machined aluminum pipe spacer with a 1/4" drain valve screwed into it, operated manually following long drives in cold moist weather. I would get some dribbling out, never a large flow. The VW emissions upgrade was performed in November 2017 with a noticeable decrease in mpg in temperatures below 50 F. When warm, I get about 42 MPG. My wife's car is a 2013 TDI DSG which never had an intercooler fluid collection issue. Her mileage took a 10 MPG drop in cold weather, but gets up to 42 MPG over long trips and warmer temperatures. Looking back, I would drill the 1/8" hole for winter use and plug it with a hose clamp for summer use, or just let the air bleed full time. Thanks for the info on this issue.
SAR_TDI is offline   Reply With Quote
Old January 1st, 2018, 11:36   #5339
PlaneCrazy
TDI(s): Gone...
My wife also had a 2013 TDI (GSW, bought back by VW June 27th), 6-sp manual. Never had an intercooler condensate issue with hers either, but my 2011's issues were never fixed even after applying the technical service bulletin. I always wondered what was different between 2011s and 2013s.
Mike
Hers: '17 Golf TSI Sportwagen 5-MT
His: '18 Sportwagen 6-MT 4MOTION
'16 Marinoni Genius/Campy Record, '94 Marinoni Special/Campy Record
PlaneCrazy is offline   Reply With Quote
Old January 4th, 2018, 13:13   #5340
calimustang
TDI(s): 2011 JSW DSG
Hmm, mines an 2011, never had a issue. Even visited chicago. No issues like ever.
2011 JSW TDI, 266k miles as of 1/4/2018 - had original HPFP to 240k. White with cornsilk beige interior, still on original turbo, DSG, 16" Steelies Wheels, solid metal roof. Mods: CP3, 5% tints all around. P3 gauge, Stage 2 Malone tune and DPF/EGR delete
calimustang is offline   Reply With Quote
Golf tdi 99 hard start from cold and yesterday won't start at all deep_sing VW MKIV-A4 TDIs (VE and PD) 17 December 13th, 2013 07:48
TDi 130 PD - Hard Start When Cold, No Start When Hot ginboomerang VW MKIV-A4 TDIs (VE and PD) 5 July 12th, 2011 12:36
Hard Start Plus Check Engine Light and Blinking Glow Plug Indicator Greg_Morgan VW MKIV-A4 TDIs (VE and PD) 13 December 21st, 2006 17:21
No Glow? Hard cold start? Check coolant temp sensor. Jimmy TDI 101 3 January 29th, 2006 08:27
Check Eng Light - Hard start - glow plug - $$$ basco2 VW MKIV-A4 TDIs (VE and PD) 9 January 27th, 2001 19:28
Page generated in 0.25354 seconds with 13 queries
[Output: 131.04 Kb. compressed to 109.62 Kb. by saving 21.42 Kb. (16.35%)]
