Yes, aside from the piston i had to do everything you did in order to change a headgasket. I too had a certain sensitivity to every little noise, clunk, you name it because I lacked confidence in the car. I made the mistake of reaching out to a well known tdi mechanic here in this community. He scared the crap out of me with all the things that were going to go wrong since I didnt bring my car to him for the repairs. Some guys make these cars out to be something worlds apart from other cars of which only they can fix but they are actually very similar. You just have to buy all the crazy tools....lol
Once you get all the loose ends tied up I am sure your car will be great for some time come. You being overly observant is just part of it...it will pass.
I originally wasn't going to share this, but Newlite you have inspired me.
I'm sure it will generate a a great deal of consternation amongst the true mechanics and trusted gurus.
Again this was my own version of a valve job and I don't reccomend it only as a
Quick fix.
In my case I did a leak down and some of the valves were not seating properly.
This is unconventional and would not be endorsed by any shop. Do at your own risk.
I used superglue and a couple of brass plunger out of flushometer.
Glued the plungers to the valve head.
Attached a piece of fuel hose with a hose clip. Then inserted a drill bit with an hose clip to other end of tubing. Left about inch or inch and half of hosing with nothing in it.
This alows for a centering if the plunger is not dead center.
A couple of drops of Acetone applied with Q-tip and let soak for a minute and the
Brass plunger came right off with a tap of chisel sideways motion.
[/URL]
[/URL][/IMG]
On youtube.
http://m.youtube.com/watch?v=UmqAIqmJLVI
You obviously have to turn the camshaft to open the valves and apply the paste.
Then close so they are seated. I thoroughly cleaned with water and a air hose afterward.
Again I know this is a Farmers way and I don't expect any ringing endorsements.
But I will say after doing leak down just using water they all pretty much held.
100% better.
